Hi, i need to draw 2D gears with tooth i know just:
Module m=10mm
Number of Teeth= Za=13 Zb=30
To drow i need to know diameters and wheelbase size so i calculated according formules:
Holding on the drive angle=26,6degree
d=mz
d1=130mm d2=300
Tooth crown height =10mm
Tooth height of its core=12,5mm
tooth height=22,5mm
Gear tops circle=150mm and 320mm
Knuckle its core circle=105mm and 275mm
Can some draw gears? please
gears.dwg
I know of at least one lisp routine that will draw a 2D spur gear for you. All it requires is three inputs: Pitch, Number of teeth and Pressure angle. Would that work for you?
yea it would be great, but what it means pitch? i not not very good in English. Number of teeth one gear 13 second 30.
In this drawing i just need to show 2 gears with teeth and how teeth engage (cling) each other just simple drawing 2d
From the Gears and Stuff Home Page:
Pitch: The distance between similar, equally-spaced tooth surfaces, in a given direction and along a given curve or line.
You can find Tony Hotchkiss's SPURGEAR.LSP and SPURGEAR.DCL files by following this link to the Cadalyst magazine website.
http://cadtips.cadalyst.com/standard-blocks/spur-gear-updated
this Spurgear tip, i use 2007m autocad, if i doesin't know pressure angle it will work?
am can help with loading this? i save this in autocad support directory, load this file from autocad, writing successfully loaded and what next to do?
To run the second lisp routine load the program then type 2Dgear at the command line to start it. My copy works using AutoCAD 2014.
