I'm trying to create a dynamic block for a schedule to satisfy an engineer's request. The intent is to insert this block with the text for the schedule, then array the rows for as many fixture type as we may need. Then copy the text down and edit as needed.
I've got the array set up, but when I drag the array, the first array increment shows up, but the row of the schedule does not. It is not until partway through the second increment that the row shows up, but it appears with a gap between the first and second row, so something is wrong with the offset or origin... I'm not sure.
On another post someone talked about the distance needing to be set in the Array Action Properties and not just under the parameter. I don't understand where this is.
Help!
Ey_LuminarieSchedule.dwg
Edited by yrnomad
adding block
In block editor check your column distance for the array action, it is set to 1", that should also be 0.7713", click on the symbol that looks like a lightening bolt and look in the properties manager for column offset
that did it, thanks!
I was thinking rows, and why would I need to change anything related to columns.
