foster8 Posted December 1, 2008 Posted December 1, 2008 Does anyone use or know of varying levels of design check on project drawings. We might have to use a system whereby if a drawing is of a simple light fitting bracket, if the design is poor there is no great consequence of failure and so a low level of drawing check would be performed. But if a drawing contained a design that if there was a failure then there would be a large impact in cost or danger etc. then that drawing would have a higher level of functionality check. Thanks... Quote
wannabe Posted December 1, 2008 Posted December 1, 2008 How would you like the check type to be established and then displayed? Basically, it just a code the drawing producer could put in the title block and then the checker has to look at this code to decide the level of checking. Or, would you be looking for a box to pop up and say perform this level of check and then click the button to confirm? These are loose options, just to help me understand what kind of system you're looking for. Quote
