Hi Friends, I am trying to make a autoamtic elevevation as attached. but still no luck, i dont know how to do it. please help somebody here how to make it? thanks
Automatic Elevation Level.dwg
You're trying to create an elevation marker that will "automatically" display the elevation depending on its position in a drawing?
Hi Remark, thank you for the reply. it is not as per the position of the drawing. i a gonna used the marker for our sections and elevations. the attached cad file is good. but i dont know how to do it from scratch. i want to modify and add some additional attributes. thanks
Your drawing contains a block. Explode it, edit it, add your attributes then create a new block.
Hi Remark, ok thanks very much. ill try tomorrow. thanks
Have you looked on your Tool Palettes (either the Architectural or Annotation tabs)? You'll find some dynamic blocks that may suit your purposes.
Your example has field formulas, which are dependant on other fields for the value, what other attributes are you likely to want to add to your block? If you want it to work in other directions then it may be easier to create a couple of blocks set up for x, y and z axis, I would make a block that explodes on insert which itself has 2 blocks one being your reference (zero) marker, the second to show the difference in elevation from that reference, the second block would then be copied as needed for more elevation points as they would still read the base point.
  • 3 weeks later...
Hi Steven, you are right. the example block has a field formulas. the problem is i dont know how to do this formulas. thanks
