Lisp to Select/Picking line/arc/spline to Create Polyline?
Hi Bro,
Am Looking for a Lisp to Select/Picking a Line to create a Poly-line Over the same Line or arc or spline in a "Specified Layer"
(setq cp (mapcar 'getvar '(cmdecho peditaccept)))
(if (setq ss (ssget "_:L" '((0 . "LINE,SPLINE,ARC"))))
Edited by srinak47
Try this ...
(defun c:2pl (/ cp ss)
   (progn (mapcar 'setvar '(cmdecho peditaccept) '(0 1))
          (command "_.pedit" "_m" ss "" "" "")
          (mapcar 'setvar '(cmdecho peditaccept) cp)
The answer is simply the PEDIT command (bulit-in). With the addition that if you want to convert a spline into arcs and not lines made polyline, then look for FLATTEN command (also built-in).
Thanks for the Quick reply, i think this lisp is converting the original line to a Poly-line,, but i wanted to create a new poly-line over the line or arc or circle or even poly-line ....
Like a duplicate line ofc in a "specified layer" so i can isolate them later...
Instead of overdraw on the line am looking to pick and create a new POLY-LINE
Try this ...
I think this also same as converting the line to poly line.... am looking for creating a new poly line.
Please set the DELOBJ system variable to 0 to preserve original entities (although seems to works only for splines).
Or add this line to above code:
[color=magenta]           (command "_COPY" ss "" '(0.0 0.0) '(0.0 0.0))
[/color]           (command "_.pedit" "_m" ss "" "" "")
yeah its working ... but 2 things
1.its creating a duplicate pline in the same layer,, i wanted that new pline to create in a specified layer for Eg.. "A_AREA-PL"
2.the new pline wont join together automatically or i have to pedit once after this....?
But this made my work to half,, thanks a lot man.................. i must owe you a beer :)
Edited by srinak47
errror
You didn't said above about joining the plines.
          (command "_CHPROP" ss "" "LA" "A_AREA-PL" "")
[/color]           (command "_.pedit" "_m" ss "" [color=magenta]"_J" "0.0" ""[/color])
So great :):):):):):):):):):):)
Last thing..... New P-LINE Draworder to come up..... right now new p-line creates below the line....
Edited by srinak47
To further cannibalize Tharwat's code:
[color=magenta]          (command "_COPY" ss "" '(0.0 0.0) '(0.0 0.0))[/color]
[color=magenta]          (command "_CHPROP" ss "" "_LA" "A_AREA-PL" "")[/color]
[color=magenta]          (command "_DRAWORDER" ss "" "_F")[/color]
thanks and also customized what i required
Edited by srinak47
