Jozi68
Delete Surface Slope Label style
Jozi68
I would like to delete a certain label style (that is used for surfaces) using vb.net code. Can someone help me please?
Share this post
Link to post
BIGAL
If you have a look into the sample files in 2012 they were there under I think ActiveX you should be able to find VBA example code that has a number of different CIV3d object creations obviously you should be able to do the opposite and remove. These examples seem to have disappeared in 2013+
Under the ribbon I think in 2012 it was introduced there is the ability to remove unused styles, this does what you want compared to say purge which will not remove styles.
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\en-us\Where_are_my_sample_files.html
Share this post
Link to post
