tzframpton Posted January 31, 2014 Posted January 31, 2014 Is there a way for 3ds Max to render all objects with an edge as a rounded or filleted edge, instead of applying a modifier to every single edge? Quote
Cad64 Posted January 31, 2014 Posted January 31, 2014 Do you mean that you want to leave all your edges sharp and then have them displayed as rounded in the render? You can do this, sort of, by checking an option in your material editor. 1. Apply an "Arch & Design" material to your model 2. Scroll down to the "Special Effects" rollout 3. Check "Round Corners" and enter the Fillet Radius you want to apply to the corners This is merely a shading effect though. Much like a bump map, it only gives the illusion of a rounded edge. If you zoom your camera in really close and render you will see some pretty weird results. But it does look ok when rendering from a distance. For best results you will need to manually chamfer/fillet your edges. Or better yet, work in Sub-D mode: http://blip.tv/cgtuts/an-inroduction-to-sub-d-modeling-in-3ds-max-2433911 Quote
tzframpton Posted January 31, 2014 Author Posted January 31, 2014 Do you mean that you want to leave all your edges sharp and then have them displayed as rounded in the render?Yes, that's exactly what I'm trying to do. The motivation behind it, is to add "insta-realism" to my renders. For instance, my guitar modeling project. CAD applications have this super sharp edges on everything, when in reality not many things have that sharp of an edge. So many parts are beveled or rounded on the edges, and I'd hate to have to manually do this to EVERY object. So, hence my inquiry if there was some magic button. Thanks for the tips, I'll give those a shot and see how things progress. Quote
