how to use autodesk_fabrication_cadmepoe APP
Once installed into autodesk folder, does this app just run, or do I need to do somthing to make it run? I have been given a drawing made from Revit(I think) and a install download of "autodesk_fabrication_CADmepOE" which should allow viewing of ductwork in the drawing. Im not seeing ductwork so I think I might need to do something to start the app. Any help is appreciated.
Thanks to everyone, I used "appload" command and navigated to the proper file and it worked. I was not able to view revit ductwork in the drawing provided to me without the app. Thanks again.
If you are going to be needing this on a regular basis and don't want to load it every time, you can add it to your "Start Up Suite" from the appload dialog box.
For conformity, what you got is an Object Enabler - a plug-in (usually freeware) that will allow one to see entities that were created by vertical products based on AutoCAD. What I find strange is that it doesn't integrate automatically with AutoCAD at install.
