AdrianR Posted February 5, 2014 Share Posted February 5, 2014 I have many drawings where I try to zoom all the way into edit and it won't let me. I use the wheel to zoom. In the bottom left says "already zoomed in as far as possible". Is there a setting I can change or something I can do to be able to zoom it more? I am using AutoCAD Civil 3d 2014. Thank you! Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 5, 2014 Share Posted February 5, 2014 Try doing a REGEN or REGENALL. Quote Link to comment Share on other sites More sharing options...
AdrianR Posted February 5, 2014 Author Share Posted February 5, 2014 I've tried regen. Thanks. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 5, 2014 Share Posted February 5, 2014 I have a similar issue, except that I can't zoom all the way out sometimes. I will never understand why that is though. You could use zoom window to zoom in closer. Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 5, 2014 Share Posted February 5, 2014 I know that LIMITS sometimes messes with the Zoom-Out issue, but I can't see how it should affect the Zoom-In issue. That said, I sometimes have this problem as well, a regen often works but not always, and I always have LImits off - so I have chalked it down to One Of Those Things. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 5, 2014 Share Posted February 5, 2014 Turning limits off will solve it? I wonder why that would be. Auto Desk please. Quote Link to comment Share on other sites More sharing options...
AdrianR Posted February 5, 2014 Author Share Posted February 5, 2014 I've turned limits off and tried every zoom command, it still won't let me zoom all the way in! Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 5, 2014 Share Posted February 5, 2014 Is it possibly a matter of perception that you are not zoomed in far enough. On the display screen the lines don't get any thicker as you zoom in or out, even if you have "display lineweights" turned on. In fact they stay a constant thickness. I just zoomed in fully on the lower left corner of a 13" rectangle. Once the other three corners of the rectangle disappeared off screen, there were no visual cues to tell me how far I was zoomed in on the one corner. I took a DIST of how much of the lines I could still see. The result was 0.00008 vertical and 0.00011 horizontal. That is pretty zoomed in. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 5, 2014 Share Posted February 5, 2014 Can you take a screen shot to show us how far you are able to zoom in? Quote Link to comment Share on other sites More sharing options...
AdrianR Posted February 5, 2014 Author Share Posted February 5, 2014 I don't think that's it. This is as close as I can get. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 5, 2014 Share Posted February 5, 2014 So using zoom window wouldn't work? Have you done everything including restarting your computer? Quote Link to comment Share on other sites More sharing options...
AdrianR Posted February 5, 2014 Author Share Posted February 5, 2014 Zoom window doesn't work. This has been going on for months now so restarting won't help. Thanks. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 5, 2014 Share Posted February 5, 2014 Attach file here that exhibits this behavior. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 5, 2014 Share Posted February 5, 2014 Is it on every single drawing you open or just that one? You might have to try to re-install AutoCAD. Quote Link to comment Share on other sites More sharing options...
AdrianR Posted February 5, 2014 Author Share Posted February 5, 2014 Not on every drawing, only some. And I just upgraded to 2014 and it was doing it before. Attached is the drawing. Thanks! ZOOM.dwg Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 5, 2014 Share Posted February 5, 2014 Nope, that's definitely not the perception error I was referring to. Here's a wild idea. Has somebody left recently with a bad attitude. Maybe somebody that would have scaled down the drawings by some ridiculous factor like .00000001 to get even for something? I just tested this and one can scale down beyond the zoom in limits. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 5, 2014 Share Posted February 5, 2014 I copy and pasted the detail into another file and I could zoom as expected. Something in that file and probably has to do with the Civil program and or Geo references, etc. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 5, 2014 Share Posted February 5, 2014 OK, that is weird. I can't zoom or pan. Well, I could when I first opened the drawing (converted by TrueView to 2007) but it stopped. What's more, I could not even get the cursor too come out of the drawing area back to the CUI. The cursor WILL NOT cross the edge of the drawing area, but I can get it to show me coordinates from beyond the workspace frame. It is as though the display screen is bigger than the AutoCad window. I had to type QUIT to get out of the danged thing. I am baffled so far. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 6, 2014 Share Posted February 6, 2014 It is acting as if there is a viewport in modelspace, the viewport is active, maximized, and has Display Locked turned on. Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 6, 2014 Share Posted February 6, 2014 This is so weird. I took off all of the georeferences and I still can't move the view anywhere. I tried purging it and I can't even remove the layers you aren't using. Is this drawing possessed? Quote Link to comment Share on other sites More sharing options...
