Found some routines to specify a plot styles tables search path, some to modify the plot styles tables search path...
but couldn't find anything to retrieve (by lisp or vlisp) the actual plot styles table folder path.. You know, the one that will pop in windows explorer if you go to:
file ->plot style manager...
I also checked all vars *prefix, no success either on that path...
Anyone knows how to retrieve it?
Thanks in advance,
cheers!
I've check *prefix since many paths vars end with that
I've check *plot* for obvious reasons..
But the var is PrinterStyleSheetDir.
..autodesk...
thanks you very much Lee!
Maybe also
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-acad-object))))
(vla-get-PrinterConfigPath *files*)
(vla-get-PrinterStyleSheetPath *files*)
(vla-get-PrinterDescPath *files*)
; can do reverse and do put's
