hi,
I've a problem. I want to make the polyline offset and would like to know the coordinates of the new polyline.
I write codes, picked the polyline and offset that given distance but dont learn coordinates new poyline.
please help.
In your VBA code declare a variable for your polyline and set it to your polyline. This polyline object then has an offset method which creates a new polyline object as a variant object. You can then list the coordinates of the new polyline object.
Here is a co-ords of pline I have changed the code to use last entity created.
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy (I numb xy)
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq numb (/ (length co-ords) 2))
(setq I 0)
(repeat numb
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
; program starts here
;(setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
(setq co-ords (getcoords (car (entlast))))
(co-ords2xy)
thanks for all,
i write that codes for review. first polyline cordinates ok. but i cant learn new polyline.
I want draw third polyline between first polyline first vertex and second polyline last vertex
Private Sub CommandButton1_Click()
Dim basePnt As Variant
Dim returnObj As AcadObject
Dim distance As Double
Dim vertexPts As Variant
Dim numberofvertices As Long
On Local Error GoTo err 'On Error Resume Next
UserForm1.hide
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select Polyline"
distance = 50 'for example
returnObj.Offset (distance)
vertexPts = returnObj.Coordinates
numberofvertices = UBound(vertexPts) + 1
For i = 0 To numberofvertices - 1 Step 2
MsgBox "" & vertexPts(i) & ", " & vertexPts(i + 1)
Next i
UserForm1.show
Exit Sub
err:
If err.Number = -2147352567 Then
UserForm1.show
End If
End Sub
