Hello..
i have little problem in Autocad white hatching,
im trying hatch some closed paths which are imported from different vector software, after importing this artwork i converted lines to poly from spline
but when i try to hatch these some are happening some are not.. throwing a msg
"There might be gaps between the boundary objects, or the boundary object might be outside of the display area"
so i checked all vertex of path & tried hatching with full view of area but no use im getting the same error..
if someone can help me solve this issue it will be great.
Edited by rohithreddy
Attach a copy of the drawing to your next post. Someone here will take a look at it.
Are you able to select area's before getting this error or do you get it during the selection process?
I used to get some errors in the final stages of making a hatch when clicking the OK button but I soon found out that it was a scaling issue. If I made the scale smaller it would work, perhaps you can try the same.
