When I add dimensions to this drwaing they are displayed in a 1:1 scale that is too small for viewing. What is the scaling method to make them correctly sized and visible I can't recall?
Fdn.dwg
I'm not on my CAD computer at the moment but if you are making use of a layout with a viewport and your dimensions are in model space you will need to use annotative scaling and assign the same scale to your dimensions as you have assigned to the viewport.
