Switch between OPENED drawings (vla-activate)
I need to switch to a specific OPENED drawing between 5.
I know the name and the path
It is already OPENED
I HAVE USED THE VLA-ACTIVATE function but it opens a copy from the file adding a colon and a number at the end and as many times as I run the function it opens a new increesing the number after the colon.
Is there a way to switch to a specific previous opened drawing in the current AutoCAD session and run a command there and come back to the file where it was invoked the function?
Thanks in advance
I use the keyboard buttons to step through drawings by pressing the tow buttons Ctrl + tab
Yup. I thought I was considering all possibilities. I knew it was possible to do that. Still that doesn't solve my problem. I am looking for a specific routine that does what I explained because I want to make things automatically.
Thanks anyhow
Add the complete name of your opened drawing as shown in the code .
(defun c:Test nil
 (vlax-for doc (vla-get-Documents (vlax-get-acad-object))
   (if (eq (vla-get-fullname doc) [color=red]<complete_path_of_opened_drawing>[/color] )
     (vla-put-windowstate doc acmax)
     (vla-put-windowstate doc acmin)
(vl-load-com)
Thanks a lot, pretty much what I was looking for
  • 1 year later...
Hi,
I've tried to use this code,
It seems to minimise both windows without opening up the drawing. Any idea why it would do this. I'm using \\ in the filename
Hi,
What does the function findfile return if you try it on filename?
If I use that line in the cmdline i get
(findfile "S:\\USER\\TEST.dwg")
which is the same as what I am typing in.
Basically my code is
(defun c:SwitchDWG nil
   (if (eq (vla-get-fullname doc) Default )
(vl-load-com)
Where default gets switched out to the filepath S:\\USER\\TEST.dwg through a replace text vba code I have in excel. I have confirmed that the path exists in the file at the time of loading as I stepped through the vba code as it executed and noted that the path is there as autocad loads it.
If it helps when i run the switchdwg list i get no errors or anything so it would seem something is working.
Try:
(defun SwitchDWG (drawing)
   (if (eq (vla-get-fullname doc) drawing )
(vl-load-com)
and try
(SwitchDWG "S:\\USER\\TEST.dwg")
In a Ribbon Panel I have macros to open and activate a number of drawings and templates.
Example:
^C^C^P(vla-activate(vla-open (vla-get-documents (vlax-get-acad-object))(findfile "chroma.dwg") :vlax-false))
I added the SwitchWindows Ribbon Menu Button to my Quick Access Toolbar which makes switching between open drawings as easy as it gets.
