dsibbo Posted February 20, 2014 Posted February 20, 2014 Can anyone help me with a block problem. Whenever I click a certain block from my tool palette, it will enter the drawing and sit on Layer 0. Even if layer 0 isn't the current layer. All my other blocks will sit on whatever layer is current but this certain block just drops onto layer 0. Anyone know why this is happening and what I need to do? Quote
Tyke Posted February 20, 2014 Posted February 20, 2014 If you right click on the button in your tool palette and click on properties in the context menu, you can then in the dialog box the appears set the layer you want to insert the block on. You can for example select 'current layer' or a named layer. If the layer does not exist it will be created. Quote
dsibbo Posted February 20, 2014 Author Posted February 20, 2014 You Tyke are a legend. Thank You Quote
Tyke Posted February 20, 2014 Posted February 20, 2014 You Tyke are a legend. Thank You Don't mention it, only too pleased to be of help and I'm glad it worked for you. Quote
