Dipali Posted December 2, 2008 Posted December 2, 2008 When I am creating dwf files & I mostly use 'layout' option in plot dialguebox. but when i open that dwf file it opens in potrait mode. & we alos do not have option to rotate (which we have with pdf files) so how to make sure that dwf files always gets created & open in layout mode so can be studied properly. Quote
NBC Posted December 2, 2008 Posted December 2, 2008 Goto Windows Start Menu, then Control Panel (Printers & Faxes may also be on your Start Menu). Then select your DWF printer; check printer settings. You may need to restart AutoCAD for the changes to have any effect on DWF outputs. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Goto Windows Start Menu, then Control Panel (Printers & Faxes may also be on your Start Menu).Then select your DWF printer; check printer settings. You may need to restart AutoCAD for the changes to have any effect on DWF outputs. the answer made me think I was stupid, but after seeing the result I rememberd that I had tried this thing before from the plot dialguebox also you can go to prerites of the printer & change the default output & it had given the same result as now shown in this image. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 I figured out the cause fo my problem. i am using paper size ARCH D which is listed as arch D 22x34 how to make it 34X22? Quote
NBC Posted December 2, 2008 Posted December 2, 2008 Do as I mentioned earlier, and change the orientation to Landscape. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Do as I mentioned earlier, and change the orientation to Landscape. i did & that is why you cna see the paper (white background) in landscape(horizontal), other wise it was alos appering portrait(verticle) so now the problem is as mentioned earlier the paper is represented in dimension 22 in. x 34 in, which we need to make 34 in X 22in, now how to do that? Quote
NBC Posted December 2, 2008 Posted December 2, 2008 Change the orientation in your Page Setup within AutoCAD to be Landscape also. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Change the orientation in your Page Setup within AutoCAD to be Landscape also. it is already done. the only thing requires is to change the default paper size which i am not able. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Hey NBC If you don't mind looking at the drawing & trying the solution, I can email or pm you the drawing. this is bugging me since a month & I was putting it off for quite some time. Quote
NBC Posted December 2, 2008 Posted December 2, 2008 Sure, no worries. Should I get it working how you desire; I will post here the steps I took, for all to see. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Sure, no worries.Should I get it working how you desire; I will post here the steps I took, for all to see. Sure. I just emailed you the drawing file. I will be leaving the office soon. but will log in at home later to catch up. Quote
NBC Posted December 2, 2008 Posted December 2, 2008 Ok Dipali; I have had a little time to play with this. Here are my findings: 1. I have made no changes to the file you sent me, and have therefore not saved it. 2. I had to shut down AutoCAD, then I went to Printers & Faxes Section of Control Panel. Found the relevant dwf printer. 3. Right clicked on it, and set the orientation to Portrait. 4. Applied and Ok'd the changes. 5. Closed Printers & Faxes, and Control Panel. 6. Restarted AutoCAD. 7. Loaded up your drawing file. 8. Issued the PUBLISH command, leaving all settings to default; except where it says Publish To ( I put a blob in the DWF File radio button). 9. Clicked on Publish. 10. Clicked on Select to accept the default location and name of the DWF file. For some reason, when using PUBLISH the DWF file came out in Landscape Format; and when using PRINT or PLOT the DWF File comes out in a Portrait format; I have no idea as to why. Also, for your peace of mind, I have now deleted your files from my system. Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 thanks for you time NBC But for some reason this is not going to go away it seems. because I tried publish few times & it is getting cancelled internally. this is from publish detail dialguebox. Job: - Canceled Job ID: 11 Sheet set name: Date and time started: 12/2/2008 6:46:40 PM Date and time completed: 12/2/2008 6:46:45 PM UserID: Profile ID: Total sheets: 0 Sheets plotted: 0 Number of errors: 0 Number of warnings: 0 Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 yes, with the plot it is giving the problem for which I started this thread. Quote
NBC Posted December 2, 2008 Posted December 2, 2008 D'oh ! Did you try the steps 1 - 10 I mentioned in my post ? This is the DWF Writer I used to print/publish - http://usa.autodesk.com/adsk/servlet/index?id=10798343&siteID=123112 It is free Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 ok i retried it step by step & publish is still giving me error Quote
NBC Posted December 2, 2008 Posted December 2, 2008 See if you can install that DWF Writer I posted a link for; then set that up in your Page Setup as the printer to use. See if you get the same errors ? Quote
Dipali Posted December 2, 2008 Author Posted December 2, 2008 Its solved:) After downloading that writer it was giving me the same trouble. while publishing it was giving the same error. while playi ng in the publish dialoguebox, when i clicked on pagesetup, it highlighted the information at the bottom of dialgue box & it said that it replacing the ploter in pagesetup with dwf6eplot.pc3 becuase that is inbuilt with autocad. (and i remeber using that printer in previous job) so I figured there is something wrong woth that pc3 file. it was not getting listed in control panel, so I went ploter manager from auotcad>deleted that file & than started add ploter wizard & from my computer i browsed to that file dwf6eplot.pc3 & readded it.& guess what it had options of choosing the paper size bothways 34X22 & 22X34 so by selceting it 34X22 it soved my problem. so i was right from the beginning that problem was in how thw paper size is selected. Quote
