Software usage: AutoCAD 2000 to 09.
Is it possible to modify this code to get the dim arrow head size, variable exe & exo & dim color.
Private Sub CommandButton2_Click()
Dim objDimension As AcadDimension
Dim varPickedPoint As Variant
Dim objDimStyle As AcadDimStyle
Dim strDimStyles As String
Dim strChosenDimStyle As String
On Error Resume Next
Me.hide
ThisDrawing.Utility.GetEntity objDimension, varPickedPoint, _
"Picked a dimension whose style you wish to set"
If objDimension Is Nothing Then
MsgBox "You failed to pick a dimension object"
Exit Sub
End If
MsgBox objDimension.TextHeight
MsgBox objDimension.TextStyle
' MsgBox objDimension.VerticalTextPosition
MsgBox objDimension.TextGap
End Sub
yes this is possible, do you need help making it work?
add this
MsgBox objDimension.ArrowheadSize
MsgBox objDimension.ExtensionLineExtend
MsgBox objDimension.ExtensionLineOffset
If you pause your IDE, you can look in the Locals window and see all the info your looking for. I paused and highlighted ArrowHeadSize for you in the pic
Now that I have all my variables from my choose dimension. How can I use
these variables to change my current dim Style?? How could I make a new dimstyle with these variables.
Oh yes, Where do I find and pause my IDE window.
Thank you,
your IDE is the window where you wrote your code. To pause your code, click to the left of the line you want to pause. A red dot should show up.
Dimension overrides are a bit tricky but this code I use helps me often..
Public Sub ChgDimStyleSettings()
'Will set a dimstyle current and effect an override
'The current settings are then copied into the named set from
'the drawing (which will catch the overrides .. copying from an
'existing dimstyle will not catch overrides). After changing
'dimstyle, each dim using style is moved a bit, then returned,
'to force update. Update doesn't catch dimstyle changes.
Dim acDimStyles As AcadDimStyles
Dim acDimStyle As AcadDimStyle
Dim objEnt As AcadEntity
Dim vNewVal As Variant
Dim iVal As Integer
Dim iDS As Integer
Dim ssDim As AcadSelectionSet
Dim sSS As String
Dim iCd(0) As Integer
Dim vVal(0) As Variant
Dim vCds As Variant
Dim vVals As Variant
Dim dPt0(2) As Double
Dim dPt1(2) As Double
For iDS = 0 To 2
   dPt0(iDS) = 0#
   dPt1(iDS) = 0#
Next iDS
dPt1(0) = 1#
Set acDimStyles = ThisDrawing.DimStyles
sSS = "DIMUPDATE"
'make sure selset name is not in use .. done here since loop each add is deleted
For Each ssDim In ThisDrawing.SelectionSets
   If ssDim.Name = sSS Then ssDim.Delete
Next ssDim
'Set each Dimstyle Current
For iDS = 0 To acDimStyles.Count - 1
   ThisDrawing.ActiveDimStyle = acDimStyles(iDS)
   'CUSTOM settings here
   'vNewVal = Chr(34) 'make sure alt dims use " as suffix
   vNewVal = "STANDARD_ISO"
   'CUSTOMIZE HERE     >>>>>>>>>>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
   ThisDrawing.SetVariable "DIMTXSTY", vNewVal 'establish override
   acDimStyles(iDS).CopyFrom ThisDrawing
   'Update associated dims
   iCd(0) = 3
   Set ssDim = ThisDrawing.SelectionSets.Add(sSS)
   vVal(0) = acDimStyles(iDS).Name
   vCds = iCd: vVals = vVal
   ssDim.Select acSelectionSetAll, , , vCds, vVals
   'Update doesn't .. must actually 'touch' the dims
   For Each objEnt In ssDim
       objEnt.Move dPt0, dPt1
       objEnt.Move dPt1, dPt0
   Next objEnt
   ssDim.Delete
Next iDS
ThisDrawing.Regen acActiveViewport
'Check the setting
'''    For iDS = 0 To acDimStyles.Count - 1
'''        Set acDimStyle = acDimStyles(iDS)
'''        ThisDrawing.ActiveDimStyle = acDimStyle
'''        iVal = ThisDrawing.GetVariable("DIMCLRT")
'''        If iVal <> vNewVal Then MsgBox "Text Color is " & iVal
'''    Next iDS
Set acDimStyle = Nothing
Set acDimStyles = Nothing
Set ssDim = Nothing
End Sub
Pausing the IDE for the local windows works well. Seems like in both Visual Basic or VBA I seem to look for variables. I usually end up searching google. What about the object browser. Would that help also?
I am still looking for the annotative dim variable and how it relates to
dimscale. Any Info on that?
Thank you,
are you looking for the scale value of Annotation or how to set a style to be annotative? The first is in CANNOSCALE, the second cant be done
Is there a autocad variable for Dim Text Rotation? I found the object variable in AutoCAD VBA object but I can't find the autocad dim variable to set
dim text rotation. Does anyone know what that autocad variable is?
thank you,
I cant find that in autocad, just horz or aligned with the dim line
