matt41129 Posted December 2, 2008 Posted December 2, 2008 Hi Guys, I'm trying to flatten a architects 3D floor plan. Ive tried the "Flatten" command. This command just dont seem to work, it just seems to keep running with no progress. I wonder if the size of the building (actual dimensions) is causing this to delay the process. I let it run yesterday for about 2hrs with no progress. Anybody have any ideas? Thanks, Matt Quote
nocturne00 Posted December 3, 2008 Posted December 3, 2008 have you tried Flatshot on the Plan? Quote
fransblok Posted December 3, 2008 Posted December 3, 2008 Flatten can take some time but two hours sound like too much. You should see something happen during the proces, solids exploding and stuff. Did you try to flatten a part of the drawing? Or layer by layer? Quote
arjun_samar Posted December 3, 2008 Posted December 3, 2008 I think flatshot is the best option you have. coz i have already tried flatshot on a 3d house. Quote
f700es Posted December 3, 2008 Posted December 3, 2008 Not a good one here but it can work if your file is a problem. Set to plan view, do a hide and print to a DXB file. Open a new drawing and insert DXB file. You might have to scale back up but your image will be flat. Quote
matt41129 Posted December 3, 2008 Author Posted December 3, 2008 Thanks for all of your help. I flattened by layer. It seemed to work the best.. guess there was to much stuff to process. Thanks for all of the help. Quote
autocad_designer08 Posted December 4, 2008 Posted December 4, 2008 hi! i have encountered same problem with you before. i have tried also all the advices above but im not satisfied with the result... you can also use the solprof command to flatten 3D objects on a perfect result.... hope this could help Quote
matt41129 Posted December 6, 2008 Author Posted December 6, 2008 Ill keep that command in mind the next time i run into this type of problem. I ended up fixing it. I just had to isolate the layers and flatten one at a time. Didnt take to long but it did the job. Thanks for all of the help! Quote
arjun_samar Posted December 8, 2008 Posted December 8, 2008 dudes, i have tried flat shot and it really help me a lot. but when i flatshot a 3d perspective projection drawing the result are always not quite what i want. coz when i inserted the block the project of lines are not in perspective, sadly. so how can i flatshot a 3d perspective projection drawing? here is what i've been trying to flatshot in perspective. thanks in advance...... arjun Quote
