Dear all
Vl-some confused me. Why the variation in below lines...
(setq nlst (list 0 2 pi pi 4))
(vl-some '= nlst (cdr nlst))
T
(vl-some '= (list 1 2 3) (list 2 3))
nil
(vl-some '= '(1 2 3) '(2 3))
nil
Thanks
T
The is true because the first item from the first list is equal to the first item in the second list so it is T .
nil
This one is nill because each item from the two lists is not equal to each other so it is NIL .
nil
This one is the same like the previous one .
(vl-some '= (list 0 2 pi pi 4) (list 2 pi pi 4))
T
Please Check the above line
T
My reply was correct and indicating to the correct one .
The following one is correct due to equal items in the two lists .
(vl-some '= (list 0 2 [color=blue]pi[/color] pi 4) (list 2 pi [color=blue]pi[/color] 4))
Clear ?
Test these to see the differences .
(vl-some '(lambda (j k)
           (if (= j k)
             (print j)
        (list 0 1 7 10)
        (list 1 2 7 10)
           (if (= j k)
             (print j)
        (list 0 1 2 10)
        (list 1 2 3 10)
yes, now i understood thank you Mr. tharwat.
