Hi guys,
I have a question which hopefully will be quick. How can I reduce the distance between a text dimension and the object being measured.
I know I can use the "Text movement" under the "Fit" properties, but I want to keep the dimension text as "Keep dim line with text"
Thanks
same here :D i've checked all menu for leader but still can't find how to solve this problem, i hope there's someone can figure out this problem
What type of dimension are you using? I cannot view your image.
AFAIK, the closest you can get to an object is controlled by Arrow Size (DIMASZ), for Diameter, Radial, Angular and other Dims that are using a leader line Text Offset (DIMGAP) might help get you closer.
