One of my users keeps getting this error message as he trys to save or switch between tabs in his drawing.
Message is simply AutoCAD Error - Test Failed.
Has anyone come across this or know a fix for it?
Thanks
Dom
Has the same drawing been tested on another computer?
Yes i've tried it on mine it works fine. It isn't one drawing file he has the problem with, at the moment it is 2 drawings he's encountered it on.
WBlock out the contents of one of the drawings.
Start a new drawing.
Insert the WBlock you created.
Save the drawing under a new name.
Test it.
What happens?
Sounds like that user is running some lisp/app that is causing it. I would check and see what add-ons they are using.
