Hi all,
I am trying to learn a bit of Macro and Lisp, but I am stuck at the beginning.
Example: I want to make a shortcut for select previous elements, and try something like "move previous".
I tried macro:
^C^C_select;p;;
but it's not working.
Then I tried LISP:
(defun c:sy nil (command "select" "p" " " )(princ))
It does select previous elements, but it stays in "select mode". If I hit enter - elements get de-selected.
I tried command (like "move) first, but stil no luck...
I tried few more combinations, but you guess - no luck.
I tried also with _.PSELECT
Also does not work...
Any ideas (yes I know that this is trivial to you, but for me it's not :oops:)
Thanks,
cheers
try this.
(defun c:sy ()
(command "_.PSELECT" "p"))
So long as you have not done another selection you do not need a seperate defun sy
(command "move" "p" "") ; note "" not " "
; also
(command "move" "L" "") ; last object created
is working, thanks.:thumbsup:
I am sure I have tried this combo, but ...
However -
(defun c:sy ()
(command "select" "p" ""))
is NOT working. (When I think again, this is the combo I tried first, and as it was not working, I didn't try at all before mentioned - working - "move" command.
I am not sure why "select" combo is not working...
try this.
(defun c:sy ()
Command: SY _.PSELECT Unknown command "PSELECT". Press F1 for help.
Command: p Unknown command "P". Press F1 for help.
Command: nil
@MSasu:
I'll check the mentioned link, thanks.
However -
(defun c:sy ()
Command: nil
@MSasu:
(defun c:sy ()
(command "PSELECT" "p" ""))
Thanks for the reply, but it's still "PSELECT Unknown command "PSELECT". Press F1 for help.".
A bit odd though: when I type command, it accepts, but when I look in Cmd line history - it shows "select" although I typed "pselect". The same case when I type "._pselect". It accepts, but it is changed to "select".
Mostafa Badran, it seems that PSELECT command was discontinued in AutoCAD 2013.
On a side note, the "_." prefixes you removed from your code were responsible to ensure calling the English name of the command ("_"), respectivelly ensuring to call its built-in version and not a redefined one (".").
Thanks MSasu for clarify to me, but I tested it on 2013,2014 ,it is works fine.
I am working in AC 2014, and it gives me the error.
Strange.
Is there another way to assign "select previous" to a shortcut?
p.s. - I think MSasu was explaining to me, not to you. And, thank you MSasu for clarifying to me I really didn't know it, although it looks like basic. I don't have time to start from beginning (though I am aware that is the best and easiest way) - I just try to make a simple command - and you see where I got. :)
If it came to a choice between using _.SELECT and _.PSELECT I would suggest sticking to _.SELECT.
_.PSELECT is associated with the properties palette and appears to only be demand loaded with the palette. So if you don't have the properties palette open it is very likely that _.PSELECT will not be available. To demonstrate from the command line:
Command: arx
Enter an option [Files/Groups/Commands/CLasses/Services/Load/Unload]: unload
Enter ARX/DBX file name to unload: acopm.arx
acopm.arx successfully unloaded.
Command: pselect
Command: arx
Enter an option [Files/Groups/Commands/CLasses/Services/Load/Unload]: load
Enter ARX/DBX file name to load: acopm.arx
Command: PSELECT
Select objects: Specify opposite corner: 10 found
Select objects:
After some tests on various workstations (AutoCAD 2012, 2013 and 2014) have learned that said command works on some and not on the other. But now is clear why. Thank you, Cwake!
Thanks Mircea. No Problem.
To answer your question p0peye, another way would be to use the lisp expression (ssget "_P") to return the previous selection set.
Having said that, I think that by far the most practical approach (and the one that is most consistent with AutoCAD's intention) is what BIGAL said in post #4.
The SELECT command creates a selection set that is meant to BE the previous selection set for a subsequent command like move, copy, scale, rotate, etc. To use SELECT with PREVIOUS is actually reversing its intended use. If you already have a PREVIOUS selection set, just apply the command to it.
If decide to go with SSGET aproach, then it may worth to take a look to SSSETFIRST function, too.
Hi all, thanks for the answers.
A quick update:
(defun c:sy () nil (command "_.PSELECT" "_p" "")(princ))
Works now. Not sure why it wasn't working few days ago - thanks anyway mostafa.
I took a look at "A simple selection set LISP gone horribly wrong..." , but I still can't get the logic out of it to reproduce similar code , although I see that it's a very basic level.
Maybe in a few months...
I have tried the expression ssget "_P", but I am not doing it right. I'll take a look at the links provided on this forum about LISP basics, and try later again.
For now, mostafa's code is doing the job. How long - we'll see :)
Cheers
p.s. -
(defun c:sy () nil (command "SELECT" "_p" "")(princ))
is not working.
p.s. -
is not working.
Instead, consider:
(defun c:SY () (sssetfirst nil (ssget "_p")) (princ))
Yes, it's working, thank you. I didn't use "sssetfirst" in my experiments - that's why it wasn't working for me. As I said, as soon as I find some free time, I'll take a look at the LISP basics.
Thank you all again :thumbsup:
That is kind of you to say, but I merely demonstrated what MSasu suggested. :thumbsup:
No worries; we all start somewhere.
Cheers
Yap.
MSasu mentioned it (don't get me wrong, I am grateful to him also :) ) but I didn't know how to put it in the code right. I quickly searched the net for an example, didn't find (or didn't recognize) a useful one, and gave it up for the moment. And then you gave it to me on a golden plate ;)
Once again thanks to all for the time spent on this (for you) trivial problem,
Cheers
