I'm running autocad MEP 2014. I was for a lisp routine that'll add the quantity of pieces of text in a drawing. All my posts lately have been about adding something.....Basically I have drawings with multiple pieces of text in them. the number 20 written hundreds of times. the number 25 written hundreds of times, and so on....I'm not looking for a routing that totals them up, but a routing that'll tell me how many instances there are of each.....Right now I go to properties, then quick select, then I select text, I click on contents and then I put in a value....And I do this for every number. That's a lot of work. Is there a routine that can simplify this process? Or maybe cad can do it with a command that already exists that I don't know about?
Thanks, Jess
Try this UNTESTED routine and let me know .
(defun c:Test (/ st ss)
 (if
   (and (/= (setq st (getstring t "\n Specify string to search for :"))
        (setq ss (ssget "_X" (list '(0 . "*TEXT") (cons 1 st)(cons 410 (getvar 'ctab)))))
    (alert (strcat "You have < "
                   (itoa (sslength ss))
                   " > of your input string "
    (sssetfirst nil ss))
    (alert "Nothing found <!>")
Edited by Tharwat
Awesome. Yes it does work.....Is there any way that the routine can be modified so that when it gives me a total it also selects them so I can move them aside and delete them and move on to the next number? The reason for this is so its easier for me to chose which number I want to count next...If its cluttered with all the other numbers that I already counted its harder to find new numbers....Ideally I'd like to select the whole drawing with a command and it would populate a total list of everything.. : )
Yes. It worked! that's great! That saves me sooo many steps...Thank you.. Hopefully next I can find something that'll do all the numbers at once. You guys keep making my job easier and easier. Lol
Excellent , Good luck . :D
  • 2 weeks later...
Dear Mr.Tharwat,
i am looking for a lisp to add the text. You are kind & helping lot of peoples in this forum and I hope you could help me on this.
I don't know how to explain this, So i have attached a sample.
Want to add the plant annotation and tabulate the results or export to txt file.
Thanks
Manohar.
PLANTING.dwg
Dear Mr.Tharwat,
Thanks
Manohar.
Something like this ?
(defun c:Test (/ s i e f o x y l lst)
 ;;    Tharwat 18. mar. 2014    ;;
 (princ "\n Select texts to export to txt file :")
 (if (setq s (ssget '((0 . "TEXT") (1 . "#*"))))
   (progn (setq o (open (setq f (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) ".txt")) "w"))
          (write-line (strcat "DESCRIPTION" "\t" "QTY") o)
          (repeat (setq i (sslength s))
            (setq e (entget (ssname s (setq i (1- i))))
                  x (cdr (assoc 1 e))
                  b ""
            (while (wcmatch (setq a (substr x 1 1)) "1,2,3,4,5,6,7,8,9,0")
              (setq b (strcat b a)
                    x (substr x 2)
            (if (setq y (assoc (setq x (substr x 2)) l))
              (setq l (subst (cons x (+ (atof b) (cdr y))) y l))
              (setq l (cons (cons x (atof b)) l))
          (foreach x l (write-line (strcat (car x) "\t" (rtos (cdr x) 2 1)) o))
          (close o)
          (startapp "notepad.exe" f)
Edited by Tharwat
Thanks for the quick response.
Sorry I could not able to put what i need in thread.
Current Result
DESCRIPTION QTY
1 T/AZA.I 1
10 G/ALT.A 1
3 P/PHO.D 1
12 P/RHA.E 1
5 P/RHA.E 1
1 P/RHA.E 1
2 P/PHO.D 1
36 G/ALT.A 1
1 T/PLU.O 2
Desired Result
DESCRIPTION QTY
T/AZA.I 1
G/ALT.A 46 (36+10)
P/RHA.E 18 (12+5+1)
P/PHO-D 5 (3+2)
T/PLU.O 2 (1+1)
Edited by manohar
I updated the codes above , try it and let me know .
Wow.
Working Great. I really apprecaite your help. it is going to save lot of my time.
Thanks a Lot.
Manohar
Wow.
Thanks a Lot.
Manohar
Excellent , You're welcome Manohar and I am happy to help. :)
