Tharwat Posted July 23, 2014 Share Posted July 23, 2014 Without Vlisp . (mapcar '(lambda (x) (if (eq (car x) 10) (setq l (cons (list (cadr x) (caddr x)) l)) ) ) (entget s) ) Quote Link to comment Share on other sites More sharing options...
samifox Posted July 23, 2014 Author Share Posted July 23, 2014 What is the different between yr code and the code in the prevuos post? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 23, 2014 Share Posted July 23, 2014 What is the different between yr code and the code in the prevuos post? Did not you try them each one alone ? What did you find out ? Quote Link to comment Share on other sites More sharing options...
samifox Posted July 23, 2014 Author Share Posted July 23, 2014 Im not in front of pc but by reading i guss that ur code in the other one is about the same Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 23, 2014 Share Posted July 23, 2014 Im not in front of pc but by reading i guss that ur code in the other one is about the same Yes , and as I said before it is without VLisp function(s) . Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 23, 2014 Share Posted July 23, 2014 Another: (apply 'append (mapcar '(lambda ( x ) (if (= 10 (car x)) (list (cdr x)))) (entget <lwpolyline-entity>))) Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted July 24, 2014 Share Posted July 24, 2014 (edited) Yes , and as I said before it is without VLisp function(s) . sorry my for old post VL, some vl- vlax- functions also not need (vl-load-com) that's why i was confused now i re-post this without VL. (setq e (car(entsel))) ;select LWPOLYLINE ('((l / i j) (while l (if (setq i (assoc 10 l)) (setq j (cons (cdr i) j)) ) (setq l (cdr l)) ) j ) (entget e) ; <-- e= ename of LWPOLY ) ;wrapped in lambda due to localize i & j variables another ('((l / i) (cdr (foreach x (mapcar 'cdr l) (if (listp x) (setq i (cons x i)) ) ) ) ) (entget e) ) as far i know (vl-load-com) for collections documents? @David it was fun learning Thank you Edited July 24, 2014 by hanhphuc Quote Link to comment Share on other sites More sharing options...
martinle Posted February 16, 2018 Share Posted February 16, 2018 Hello I found these threads. I have a job to do. At the selected vertex of a closed polyline, I must place a vertical xline at both endpoints. In the thread, I can only address all key points. But I only need the selected vertex of the polyline. Please help Thank you Martin Quote Link to comment Share on other sites More sharing options...
pBe Posted February 16, 2018 Share Posted February 16, 2018 Hello... At the selected vertex of a closed polyline, .. But I only need the selected vertex of the polyline. I think you meant endpoints of a selected "segment"? Is the no Vlisp rule applies to your request? Quote Link to comment Share on other sites More sharing options...
martinle Posted February 16, 2018 Share Posted February 16, 2018 Hello pBe Yes Quote Link to comment Share on other sites More sharing options...
pBe Posted February 16, 2018 Share Posted February 16, 2018 Hello pBe Yes Yes on both counts? "segment" and "No Vlisp rule"? Quote Link to comment Share on other sites More sharing options...
martinle Posted February 16, 2018 Share Posted February 16, 2018 Hello pBe I Click on a segment of the polyline and need the endpoints to the left and right of the click point. Thank you Martin Quote Link to comment Share on other sites More sharing options...
pBe Posted February 16, 2018 Share Posted February 16, 2018 (edited) Quick Mod (Defun c:demo (/ en param) (setq en (entsel)) (setq param (vlax-curve-getParamAtPoint (Car en) (vlax-curve-getclosestpointto (Car en) [color="blue"](trans (cadr en) 1 0)[/color]) ) ) (foreach pt (mapcar '(lambda (p) [color="blue"](trans [/color](vlax-curve-getPointAtParam (Car en) p)[color="blue"] 1 0)[/color] ) (list (fix param) (1+ (fix param))) ) (entmake (list '(0 . "XLINE") '(100 . "AcDbEntity") '(100 . "AcDbXline") (cons 10 [color="blue"](trans pt 0 1)[/color]) (cons 11 (getvar "UCSYDIR")) ) ) ) (princ) ) trans function is your friend Edited February 16, 2018 by pBe UCS Friendly Quote Link to comment Share on other sites More sharing options...
martinle Posted February 16, 2018 Share Posted February 16, 2018 Hello pBe Thanks for the quick help. It does not always work. If I work in the user UCS then only on one side an Xline is created. Martin Quote Link to comment Share on other sites More sharing options...
pBe Posted February 16, 2018 Share Posted February 16, 2018 (edited) I'll look into it later, stepped out for lunch Code at post 33 updated Edited February 16, 2018 by pBe Quote Link to comment Share on other sites More sharing options...
martinle Posted February 16, 2018 Share Posted February 16, 2018 Hello pBe Thanks Quote Link to comment Share on other sites More sharing options...
martinle Posted February 19, 2018 Share Posted February 19, 2018 Hello pBe it works. Thank you very much for your help. I have one more question: what should I change so that instead of vertical xlines horizontal xlines are set? Thank you Martin Quote Link to comment Share on other sites More sharing options...
pBe Posted February 19, 2018 Share Posted February 19, 2018 Hello pBe...Thank you very much for your help. I have one more question: what should I change so that instead of vertical xlines horizontal xlines are set?.. Good for you (getvar "UCSYDIR") -> (getvar "UCSXDIR") Quote Link to comment Share on other sites More sharing options...
martinle Posted February 19, 2018 Share Posted February 19, 2018 Hello pBe Many thanks Martin Quote Link to comment Share on other sites More sharing options...
