On 1/5/2007 at 3:38 AM, ASMI said:
It seems good idea to me has come. It is possible to transform existing polylines to pipes.
(defun c:plp(/ lSet plLst pl pl1 pl2 oldOsm
      actDoc vLst1 vLst2 stLst *error*)
 (vl-load-com)
 (defun GetPlineVer(plObj)
   (mapcar 'cdr
    (vl-remove-if-not
     '(lambda(x)(=(car x)10))
     (entget plObj)))
   ); end of GetPLineVer
 (defun asmi-LayersUnlock(/ restLst)
 (setq restLst '())
 (vlax-for lay
    (vla-get-Layers
            (vla-get-ActiveDocument
              (vlax-get-acad-object)))
   (setq restLst
    (append restLst
      (list
        (list
         lay
          (vla-get-Lock lay)
   (vla-get-Freeze lay)
         ); end list
        ); end list
      ); end append
   ); end setq
   (vla-put-Lock lay :vlax-false)
   (if
     (vl-catch-all-error-p
(vl-catch-all-apply
  'vla-put-Freeze(list lay :vlax-false)))
     t)
   ); end vlax-for
 restLst
 ); end of asmi-LayersUnlock
 (defun asmi-LayersStateRestore(StateList)
 (foreach lay StateList
   (vla-put-Lock(car lay)(cadr lay))
    (if
(vl-catch-all-apply
  'vla-put-Freeze(list(car lay)(nth 2 lay))))
     t)
   ); end foreach
    ); end of asmi-LayersStateRestore
 (if(not duct:pWd)(setq duct:pWd 1.0))
 (setq oldWd duct:pWd
duct:pWd(getdist
     (strcat "\nSpecify pipes diameter <" (rtos duct:pWd) ">: "))
); end setq
 (if(null duct:pWd)(setq duct:pWd oldWd))
(princ "\n>>> Select polylines <<< ")
 (if
   (setq lSet
   (ssget '((0 . "LWPOLYLINE"))))
  (setq stLst(asmi-LayersUnlock)
	plLst(mapcar 'vlax-ename->vla-object
	       (vl-remove-if 'listp
                        (mapcar 'cadr(ssnamex lSet))))
	); end setq
  (vla-StartUndoMark
    (setq actDoc
		  (vlax-get-acad-object))))
  (foreach pl plLst
  (command "_.fillet" "_r" duct:pWd)
  (command "_.fillet" "_p"
	   (vlax-vla-object->ename pl))
  (setq pl1(car(vlax-safearray->list
	     (vlax-variant-value
	       (vla-Offset pl (/ duct:pWd 2)))))
	pl2(car(vlax-safearray->list
	     (vlax-variant-value
	       (vla-Offset pl (-(/ duct:pWd 2))))))
	vLst1(GetPlineVer
	       (vlax-vla-object->ename pl1))
	vLst2(GetPlineVer
	       (vlax-vla-object->ename pl2))
	); end setq
  (vla-put-ConstantWidth pl1 0.0)
  (vla-put-ConstantWidth pl2 0.0)
  (vla-Delete pl)
  (foreach itm vLst1
    (setq oldOsm(getvar "OSMODE"))
    (setvar "OSMODE" 0)
    (command "._line" itm (car vLst2) "")
    (setvar "OSMODE" oldOsm)
    (setq vLst2(cdr vLst2))
    ); end foreach
    (asmi-LayersStateRestore stLst)
   ); end foreach
  (vla-EndUndoMark actDoc)
  ); end progn
   ); end if
 ); end of c:plp
 (vl-load-com)
   (mapcar 'cdr
    (vl-remove-if-not
     (entget plObj)))
 (setq restLst '())
 (vlax-for lay
    (vla-get-Layers
   (setq restLst
    (append restLst
      (list
        (list
         lay
          (vla-get-Lock lay)
         ); end list
        ); end list
      ); end append
   ); end setq
   (if
(vl-catch-all-apply
     t)
   ); end vlax-for
 restLst
    (if
(vl-catch-all-apply
     t)
   ); end foreach
duct:pWd(getdist
); end setq
 (if
   (setq lSet
	); end setq
  (vla-StartUndoMark
    (setq actDoc
  (foreach pl plLst
	     (vlax-variant-value
	     (vlax-variant-value
	vLst1(GetPlineVer
	vLst2(GetPlineVer
	); end setq
  (vla-Delete pl)
  (foreach itm vLst1
    (setvar "OSMODE" 0)
    ); end foreach
   ); end foreach
  ); end progn
   ); end if
 ); end of c:plp
can you do this with 3 polyline central from pipe , Please.
Yes is the answer.
Search for duct lisps. Plenty out there most work just that way draw centre then offset.
  • 4 months later...
Good Morning Forum,
I know this is very late asking but I have only recently downloaded the modified lisp WPipe[12] by Ronso but when I type duct, pipe or tray in to the command line after loading the lisp non of these commands are calling on the lisp. The message I am getting is unknown command. Can anyone help me with this?
  • 3 years later...
On 2/24/2007 at 2:53 PM, ASMI said:
I have executed some wishes of Vigilante. Now it is possible to not enter width each time and a pipe remains by pressing Esc.
(defun c:dpipe(/ actDoc ang1 ang2 ang3 ptLst enDist
       fPt lEnt lObj lPln oldVars oldWd
       plEnd plStart1 plStart2 prDir
       segLst Start stDist stLst tAng
       vlaPln cFlg *error*)
 (vl-load-com)
   (mapcar 'cdr
    (vl-remove-if-not
     (entget plObj)))
 (defun asmi-PlineSegmentDataList(plObj / cLst outLst)
  (setq cLst
   (vl-remove-if-not
     '(lambda(x)(member(car x) '(10 40 41 42)))
     (entget plObj))
  	 outLst '()
   ); end setq
 (while cLst
   (if(assoc 40 cLst)
      (setq outLst
     (append outLst
      (list
	(list
	  (cdr(assoc 10 cLst))
	  (cdr(assoc 40 cLst))
	  (cdr(assoc 41 cLst))
	  (cdr(assoc 42 cLst))
	 ); end list
); end list
     ); end if
); end setq
      (repeat 4
(setq cLst(cdr cLst))
); end repeat
      ); end progn
     (setq outLst
     (append outLst
     (list
       (list
	); end list
       ); end list
    ); end append
   cLst nil
   ); end setq
     ); end if
   ); end while
 outLst
   ); end of asmi-GetPlineSegmentData
 (setq restLst '())
 (vlax-for lay
   (vla-get-Layers
   (setq restLst
    (append restLst
      (list
        (list
         lay
          (vla-get-Lock lay)
         ); end list
        ); end list
      ); end append
   ); end setq
   (if
(vl-catch-all-apply
     t)
   ); end vlax-for
 restLst
    (if
(vl-catch-all-apply
     t)
   ); end foreach
 (defun PipeMLineStyle(/ dxfLst mlDict)
 (setq dxfLst
  (list'(0 . "MLINESTYLE")'(102 . "{ACAD_REACTORS")'(102 . "}")
   '(100 . "AcDbMlineStyle") '(2 . "DUCT_PIPE")
   '(70 . 272)'(3 . "")'(62 . 256)'(51 . 1.5708)'(52 . 1.5708)
   '(71 . 2)'(49 . 0.5)'(62 . 256)'(6 . "BYBLOCK")
   '(49 . -0.5)'(62 . 256)'(6 . "BYBLOCK"))); end setq
   (if
    (null
     (member
      (assoc 2 dxfLst)
        (dictsearch
  (namedobjdict)
  "ACAD_MLINESTYLE")))
     (setq mlDict
      (cdr
        (assoc -1
  (dictsearch
    (namedobjdict)
    "ACAD_MLINESTYLE"))))
     (dictadd mlDict
        (cdr(assoc 2 dxfLst))(entmakex dxfLst))
     ); end progn
   ); end if
); end of PipeMLineStyle
(defun SideCalculate(Rad Ang)
 (setq Ang(- pi Ang))
     (sqrt(-(* 2(expt Rad 2))(* 2(expt Rad 2)(cos Ang))))
     (sin(- pi Ang)))(sin(/(- pi(- pi Ang))2)
 ); end of SideCalculate
 (defun BodyFunction()
 (if
   (not
     (equal lObj(entlast)))
 (setq lEnt(entlast)
 	segLst(asmi-PlineSegmentDataList lEnt)
 	vlaPln(vlax-ename->vla-object lEnt)
 ); end setq
 (setvar "OSMODE" 0)
 (setvar "CMDECHO" 0)
 (while (/= 1(length segLst))
      (setq stDist
      (vlax-curve-getDistAtPoint vlaPln
	(caar segLst))
     enDist
	(caadr segLst))
     ); end setq
   (if(< 2(length segLst))
      (setq ang1
      (+(/ pi 2)(angle(caar segLst)(caadr segLst)))
     ang2
      (+(/ pi 2)(angle(caadr segLst)(car(nth 2 segLst))))
     ); end setq
      ); end progn
     ); end if
   (if
     (or
(not Start)
prDir
);end or
      (setq plStart1
       (vlax-curve-getPointAtDist vlaPln
	 stDist)
     Start T); end setq
      (setq plStart1
	 (+ stDist(SideCalculate(cadar segLst)ang3)))); end setq
     ); end if
   (if(and ang1 ang2)
     (if(> ang1 ang2)
 (setq ang3(- ang1 ang2))
 (setq ang3(- ang2 ang1))
 ); end if
      (setq ang3(- pi ang3)
     tAng ang3)
      (if(minusp ang3)(setq ang3(- ang3)))
      ); end progn
     ); end if
   (if
     (or
       (equal ang1 ang2 0.000001)
(= 2(length segLst))
      ); end or
     	  (setq plEnd
	   enDist)
	prDir T); end setq
         (setq plEnd
	    (- enDist(SideCalculate(cadar segLst)ang3)))
	prDir nil); end setq
     ); end if
   (if
      (setq plStart2
	 (+ enDist(SideCalculate(cadar segLst)ang3)))); end setq
     ); end if
       (if
	 (=(cadar segLst)(nth 2(car segLst)))
	  (setq ptLst
                    (mapcar
	      '(lambda(x)(trans x 0 1)); end lambda
                (list(polar plEnd ang1 (/(cadar segLst)2))
		     (polar plEnd (+ pi ang1)(/(cadar segLst)2))
		     (polar plStart2 (+ pi ang2)(/(cadar segLst)2))
		     (polar plStart2 ang2 (/(cadar segLst)2))
	      	); end list
	          ); end mapcar
		); end setq
	 (setq ptLst
	   (mapcar
	       (list (polar plStart1 ang1 (/(cadar segLst)2))
		     (polar plStart1 (+ pi ang1)(/(cadar segLst)2))
		     (polar(caadr segLst)(+ pi ang2)(/(nth 2(car segLst))2))
		     (polar(caadr segLst)ang2(/(nth 2(car segLst))2))
		     ); end list
	          ); end mapcar
		); end setq
       ); end if
 ); end if
     (setq plStart1(trans plStart1 0 1)
      plEnd(trans plEnd 0 1)
  ); end setq
   	(if plStart2
     		(setq plStart2(trans plStart1 0 1))
     	); end if
      (if
 (and
  (or
      (not(equal ang1 ang2 0.000001))
      (/=(cadar segLst)(nth 2(car segLst)))
    ); end or
   ); end and
       	(setvar "PLINEWID" 0.0)
       	(command "_.pline")
	(mapcar 'command ptLst)(command "_c")
       	(setvar "PLINEWID" dpipepWd)
); end progn
 ); end if
   (if
     (and
     ); end and
      	(setq lPln
      (vlax-ename->vla-object(entlast))
      tAng(- ang2 ang1)
     ); end setq
       (if(minusp tAng)(setq tAng(- tAng)))
        (if
	  (and
	   (< 0 tAng)
	   (>= pi tAng)
	   ); end and
       		(vla-SetBulge lPln 1 (/(- ang2 ang1)4))
       		(vla-SetBulge lPln 3 (/(- ang1 ang2)4))
         ); end progn
	   (if(< ang1 ang2)
	     (setq ang1(+ ang1 pi)
		   ang2(- ang2 pi)); end setq
	     (setq ang1(- ang1 pi)
		   ang2(+ ang2 pi)); end setq
	     ); end if
	   ); end progn
	 ); end if
      ); end progn
 ); end if
 (if
   	 (command "_.mline" "_st" "DUCT_PIPE"
	"_S" (cadar segLst) "_J" "_Z"
	plStart1 plEnd "")
   ); end if
   (setq segLst(cdr segLst)); end setq
   ); end while
 (command "_.erase" lEnt "")
 ); end progn
   ); end if
   ); end of Body Function
   (defun *error*(msg)
   (BodyFunction)
   (if oldVars
     (mapcar 'setvar
     '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE")
     oldVars); end mapcar
    ); end if
    (if actDoc
     ); end if
   ); end of *error*
 (PipeMLineStyle)
 (if(not dpipepWd)(setq dpipepWd 1.0))
 (setq oldWd dpipepWd
oldVars(mapcar 'getvar '("FILLMODE" "PLINEWID" "CMDECHO" "OSMODE"))
       ); end setq
 (if(entlast)(setq lObj(entlast)))
 (vla-StartUndoMark
  (setq actDoc
 (initget 128)
 (while(not cFlg)
  (setq fPt
 (getpoint
   (strcat
     "\nSpecify start point or width <"
     (rtos dpipepWd) ">: " ))); end setq
   (cond
     ((= 'LIST(type fPt))
      (setq cFlg T)
      ); end condition #1
     ((= 'REAL(type(distof fPt)))
      (setq dpipepWd(distof fPt)); end setq
      ); end condition #2
     (T
      (princ "\nInvalid option keyword! ")
      ); end condition #3
     ); end cond
   ); end while
   (mapcar 'setvar
 '("FILLMODE" "PLINEWID" "CMDECHO")
 (list 0 dpipepWd 0)); end mapcar
 (command "_.pline" fPt)
 (setvar "CMDECHO" 1)
 (while(= 1(getvar "CMDACTIVE"))
   (command pause)
   ); end while
 (BodyFunction)
(mapcar 'setvar
     oldVars); end apply
 ); end of c:dpipe
Hi Asmi,
This LISP works very well.
I am unable to make it work on left/right views (with UCS View), as it makes a double offset without filleting.
Is it possible to add this feature?
Thanks
Edited by whosa
  • 2 years later...
Good day to all
I would like to ask if someone would be able to modify WPIPE [11] so that instead of entering the type of elbow, user could choose from a drop-down list. The same for the other choices. Or even better create something like a simple UI with all selecting options.
Welcome aboard.
There is plenty of draw elbow software out there and yes some may have the make a choice.
You can enter a name, pick from a pop menu images, use a custom dcl with images , or select from a list.
Did you try contacting the author of WPIPE(11)
Edited by BIGAL
  • 1 month later...
I'd like to report a small bug with WPIPE[12] that's does not occur in WPIPE[11].
After choosing all settings user can't change pipe width before drawing like in WPIPE[11]. Typing new width just places first point of pipe.
Why not use the specialized toolset MEP?
Since it's FREE, I doubt if anyone is very interested in continuing to update/repair the WPIPE LISPs.
Currently, I have to use pure CAD at work. I can't download the MEP version. We're slowly starting to implement REVIT, but it will take time.
It seems non productive to not get a FREE program to do what you need.
Maybe I'll have time later today to look at them, I have these LISPs from a while back, though I may have skipped some versions.
So just to make any time spent on this worthwhile, what exactly are you looking to do and what, besides the error and select elbow from dropdown, that you mentioned?
What standards do you use?
What size ranges do you work with?
Are you doing pipe, ducts, cable trays, etc.
Overall, Lisp works as expected. I mainly use it to draw simple cable trays. I know that creating things like T-junctions and branches will be impossible, so I'm not even asking for that. Width range we use between 50-500mm most often 100mm and 200mm.
Ill look into them, although I would appreciate if someone would at least fix this bug i mentioned.
.... 800+ lines of code to look at, understand and then to work out a fix....
I doubt if I'll have time this week.
Like the others 800 lines of code, I struggle remembering what I wrote around that number of lines from a year or two ago. Having to work out why program not working with some new dwg's 678 lines of code at the moment. I had to write an error trap to just find where it was failing. You have been offered other solutions, the Tharwat solution would be my pick and he is a regular here so you could contact him if you had questions or want more.
Edited by BIGAL
Generally were busy people this week - if you open the LISP in a text editor, search for the line that asks for the new width - problem will be sometime after that - but will narrow down the issue a bit and give a less daunting task
At home I have some file compare programs, Notepad++ with the Compare plug-in as well.
IIRC, there are some online as well, WinMerge I think is one of my programs, I use AntiTwin to find duplicate files, it may have a compare function.
So while everyone is doing there jobs, if YOU have the time, you might could compare the file and see what all is different.
At least that will be a start, maybe I can talk IT into putting one of those programs on my work computer.
I used to have a program from CabloFil, not sure if they still have anything for doing cable trays in AutoCAD.
Here it is... Cable Management 3D Modeling Tools | Legrand
I haven't done a cable tray in ages, so not sure what all it does.
