highflybird Posted March 12, 2014 Posted March 12, 2014 This code can change line to leader,but not support PLINE and Can't choose which side of the arrow Who can help me? Thanks ! (defun c:tt () (setvar "CMDECHO" 0) (if (setq ss (ssget '((0 . "LINE")))) (progn (setq i -1) (repeat (sslength ss) (setq ent (entget (ssname ss (setq i (1+ i)))) p1 (cdr(assoc 10 ent)) p2 (cdr(assoc 11 ent))) (command "_.LEADER" p1 p2 "" "" "N") ) (command "_.ERASE" ss "") )) (setvar "CMDECHO" 1) (princ) ) Quote
Tharwat Posted March 12, 2014 Posted March 12, 2014 Select single line or Polyline with two coordinates only and let me know . (defun c:test (/ s ld sn 1p 2p 3p 4p gr l) ;; Tharwat 12. Mar. 2014 ;; (princ "\n Select Single line or Polyline to two coordinates only " ) (if (setq s (ssget "_+.:S:E:L" '((-4 . "<OR") (0 . "LINE") (-4 . "<AND") (0 . "LWPOLYLINE") (90 . 2) (70 . 0) (-4 . "AND>") (-4 . "OR>") ) ) ) (progn (defun ld (a b) (entmakex (list '(0 . "LEADER") '(100 . "AcDbEntity") '(100 . "AcDbLeader") (cons 10 a) (cons 10 b) ) ) ) (while (eq (car (setq gr (grread t 13 0))) 5) (redraw) (if (< (distance (setq 1p (vlax-curve-getstartpoint (setq sn (ssname s 0))) ) (cadr gr) ) (distance (setq 2p (vlax-curve-getendpoint sn)) (cadr gr)) ) (progn (grdraw 1p (cadr gr) 1 1) (if l (entdel l) ) (setq l (ld 1p 2p)) ) (progn (grdraw 2p (cadr gr) 1 1) (if l (entdel l) ) (setq l (ld 2p 1p)) ) ) ) (if (eq (car gr) 3) (entdel sn) ) ) ) (redraw) (princ) ) Quote
highflybird Posted March 13, 2014 Author Posted March 13, 2014 Select single line or Polyline with two coordinates only and let me know . Oh! very Good, nice code. Tharwat,Thank you so much! Quote
Tharwat Posted March 13, 2014 Posted March 13, 2014 Oh! very Good, nice code. Tharwat,Thank you so much! Excellent , You're welcome . Quote
