Guest Posted March 13, 2014 Posted March 13, 2014 I find here this lisp http://cadtips.cadalyst.com/distance/determine-distance-between-points-entity (defun c:DBP (/ AT:DrawX AT:CycleThroughSS p1 ent p2 d1 d2 dlst) ;; Calculate distance between 2 specified points on curve object ;; Alan J. Thompson, 03.20.10 / 03.28.10 / 03.07.11 / 05.09.11 (vl-load-com) (defun AT:DrawX (P C) ;; Draw and "X" vector at specified point ;; P - Placement point for "X" ;; C - Color of "X" (must be integer b/w 1 & 255) ;; Alan J. Thompson, 10.31.09 (if (vl-consp P) ((lambda (d) (grvecs (cons C (mapcar (function (lambda (n) (polar P (* n pi) d))) '(0.25 1.25 0.75 1.75) ) ) ) P ) (* (getvar 'viewsize) 0.02) ) ) ) (defun AT:CycleThroughSS (ss / l i e) ;; Cycle through a selection set to choose one ;; ss - selection set ;; Alan J. Thompson, 03.30.11 (if (eq (type ss) 'PICKSET) (if (eq (setq l (sslength ss)) 1) (ssname ss 0) (progn (princ "\n<Tab> to cycle through entities: ") (redraw (setq e (ssname ss (setq i 0))) 3) (while (eq (cadr (grread nil 10)) 9) (mapcar 'redraw (list e (setq e (ssname ss (setq i (rem (1+ i) l))))) '(4 3)) ) (redraw e 4) e ) ) ) ) (redraw) (if (and (AT:DrawX (setq p1 (getpoint "\nSpecify first point on curve: ")) 3) (or (setq ent (AT:CycleThroughSS (ssget "_C" (list (car p1) (cadr p1)) (list (car p1) (cadr p1)) '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")) ) ) ) (progn (alert "Point must be on curve!") (redraw)) ) (progn (redraw ent 3) T) (AT:DrawX (setq p2 (getpoint p1 "\nSpecify next point on curve: ")) 3) (or (and (ssget "_C" (list (car p2) (cadr p2)) (list (car p2) (cadr p2)) '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")) ) (setq d1 (vlax-curve-getDistAtPoint ent (trans p1 1 0))) (setq d2 (vlax-curve-getDistAtPoint ent (trans p2 1 0))) ) (progn (alert "Points must be on curve!") (redraw)) ) ) ((lambda (dist / div) (while (< dist (- (cadr dlst) (setq div (/ (cadr dlst) 100.)))) (grdraw (trans (vlax-curve-getPointAtDist ent dist) 0 1) (trans (vlax-curve-getPointAtDist ent (setq dist (+ div dist))) 0 1) 1 ) ) (princ) (alert (strcat "Distance between points on curve: " (rtos (abs (- d1 d2))))) ) (car (setq dlst (vl-sort (list d1 d2) (function <)))) ) ) (and ent (redraw ent 4)) (princ) ) For open polylines works fine. When i have a close polyline give me one direction results. I try to Reverse the polyline but gives me the same results. Can someone convert it 1) Open or Close polyline [O/C] if it is open is ok 2) for Close polyline ask CW or CCW Something like this. Look the attach photos and you will understand Thanks Quote
marko_ribar Posted March 13, 2014 Posted March 13, 2014 I would use plav.lsp to add start-end vetices on polyline and then use plpath.lsp to create new polyline between these 2 points - both options are available [TOP/BOTTOM] - [CW/CCW]... Then I would just get length of new polyline by LIST command, or for more precise use (vl-load-com); (rtos (vla-get-length (vlax-ename->vla-object (car (entsel)))) 2 50) and pick newly created polyline... For pline tools by M.R. (plpath.lsp+plintav.lsp+plav.lsp+pldv.lsp) check this link : http://www.cadtutor.net/forum/showthread.php?67924-Draw-polyline-along-with-2-or-more-adjacent-closed-polylines/page3&highlight=plpath&p=#25 M.R. Quote
Snownut Posted March 13, 2014 Posted March 13, 2014 Search for a reverse polyline direction function, I seem to recall seeing one in the past couple of weeks. Quote
Guest Posted March 13, 2014 Posted March 13, 2014 Search for a reverse polyline direction function, I seem to recall seeing one in the past couple of weeks. Autocad have comand to Reverse direction but the lisp give the same results.Understand a close polyline as open and measure the distanse with direction from the first point to last. Can anyone fix it ? Thanks Quote
