I am having an issue when trying to publish multiple sets of drawings in Autocad 2005 using the 'publish' tool. It works fine when i publish 1 copy but as soon as i try to publish 2 or more copies at a time it doesn't work. the 'plot and publish details' window says that the job was plotted with errors with the error 'load failed'. The jobs appear in the printer window with the status 'spooling' and sit there till I restart the computer. The same error occurs on both our printers (Oce TDS320 & Oce CS172). Oce have been out and suggest its a software issue, i've looked through lots of settings but nothing seams to work. 2 weeks ago I could do this without any problems
Any ideas????
thanks
Have you changed to the print setting to "enable background plotting/printing"? I find this can cause a few problems; not plotting images, freezing up etc. Maybe it's causing your problem, too?
