Tharwat Posted November 21, 2014 Posted November 21, 2014 Another advanced one to obtain your new needs of the program (defun c:test (/ ss i st l lst s) (if (setq ss (ssget "_X" '((0 . "*TEXT") (1 . "*IBM*,*COUPLER*,*Form savers*,*coupler*,*THREAD*,*THREADING*" ) ) ) ) (progn (repeat (setq i (sslength ss)) (setq st (cdr (assoc 1 (entget (ssname ss (setq i (1- i))))))) (if (not (member st lst)) (setq lst (cons st lst)) ) ) (if lst (progn (mapcar '(lambda (u) (if (vl-some '(lambda (x) (wcmatch x u)) lst) (setq l (cons (vl-string-trim "*" u) l)) ) ) '("*IBM*" "*COUPLER*" "*Form savers*" "*coupler*" "*THREAD*" "*THREADING*" ) ) (alert (strcat "You have used < " (substr (setq s (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) l) ) ) 1 (1- (strlen s)) ) " > in this drawing" ) ) ) ) ) (alert "Couldn't find any of these strings < IBM,COUPLER,Form savers,coupler,THREAD,THREADING > in drawing " ) ) (princ) ) Quote
dreams Posted November 21, 2014 Author Posted November 21, 2014 Hi Tharwat, It's working very fine what i expected... Thanks a lot. This lisp will save lot of our future problems. Thanks again... Quote
Tharwat Posted November 21, 2014 Posted November 21, 2014 Hi Tharwat, It's working very fine what i expected... Thanks a lot. This lisp will save lot of our future problems. Thanks again... You are very welcome Quote
