tried to disable those reg values "EnableCommunicationCenter", "EnableNonPatchNotifications" and "MaintenancePatchNotificationOption" to 0 (zero).
tried to rename WSCommCntr4.exe (located here: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\lib) to something else , but its still pop ups .
Anyone have a solution ?
Thanks
Edited by danielk
Owen Wengard posted a .msi file that takes care of the problem. I just included a link to a site where it could be downloaded recently. Try searching on "CommCenter".
Open the Windows Task Manager and click on the Processes tab. Scroll down to the bottom of the list until you find the entry WSCommCntr4.exe and kill it. Close Task Manager when you are done.
The CommCenter is also known as the InfoCenter. Take a look at this from AutoDesk...http://knowledge.autodesk.com/support/autocad-architecture/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-disable-the-Communication-Center-in-Autocad-s.html
Each startup it will run again . so this is not a good option
The Wengard .msi fix should have worked on your version of AutoCAD. If it didn't then these are the only other fixes I know of.
