JHayes Posted March 17, 2014 Posted March 17, 2014 Does anyone know how to change the color of an array path. I created it on one layer but when I change the color of that layer the array path does not change. Quote
jnoltremari Posted March 17, 2014 Posted March 17, 2014 Make sure "Object Color" is set to "ByLayer" Quote
JHayes Posted March 17, 2014 Author Posted March 17, 2014 Already set to "ByLayer". The other objects on that same layer change color, just not the array path. Match Properties doesn't do the trick. The settings seem to be the same as everything else on that layer though. Quote
jnoltremari Posted March 17, 2014 Posted March 17, 2014 Try making the changes from the "arrayedit" command Command Line: arrayedit (then select the array) S (for source) then select the original object, then do your layer/color/bylayer editing from there. Click "Save Changes" when done. Quote
JHayes Posted March 17, 2014 Author Posted March 17, 2014 That did it! Thank you very much. Strange stuff going on with them arrays... Quote
