Hope someone can help me figure this out!!
I use cutepdf to PDF drawings, but instead of printing out in landscape orientation (most of our drawings are landscape) the PDF is in portrait :?.
I have tried to amend the properties of cutepdf in the plotters dialog - printer properties - custom properties- landscape, but this only results in getting a landscape drawing on portrait paper! so you only see half the drawing! Is there a way I can set my cutepdf to print in landscape on landscape paper because printing to PDF then using adobe to change the orientation is driving me crazy!:x
The paper orientation is controled by AutoCAD's print setings - please check that at the right-bottom corner of PLOT command dialog there is a small round button with an arrow that will allow you to expand the dialog to have access to more options including paper's orientation.
Thanks, but I should have said this was already set to Landscape;) Am not as green as I am cabbage looking!
I have also noticed this with CutePDF, but as I got the programme for free, I have not let it upset me.
When I do want to make a PDF aligned as I would want, I use DWG Trueview, which is also for free.
Thanks, I will look into DWG Trueview!
