wesleyaqua Posted March 18, 2014 Posted March 18, 2014 hi i'm trying to make an menu my code looks like-> ID_sprinklers [->] [spbesf]^c^c -insert *file \\ 1 0 \\test;test;test what i'm trying to do is having a pulldown menu sprinkler ->spbesf insert exploded block with user pickpoint with scale 1 and rotate 0 then automated file attedit with 3 lines of test at work it didn't work. does anyone have ideas for what i try could it be the dwg i try to insert that needs to change i'm making it in an mnu for creating a big list there are plenty more options to chose afterwards. Quote
BIGAL Posted March 19, 2014 Posted March 19, 2014 The file name is probably your main problem try this [spbesf]^c^c -insert *file \\ 1 0 [url="file://\\test;test;test"]\\test;test;test[/url] [spbesf]^c^c -insert spbesf drag \ 1 0 test test2 test3 Quote
