Sooshiant Posted March 20, 2014 Posted March 20, 2014 I have hundreds of lines with different lengths and need to change each to a rectangular with the same length and a specified width. Quote
MSasu Posted March 20, 2014 Posted March 20, 2014 To do it manually you should call OFFSET and create a copy at the required width, then close the contour by two lines; using PEDIT may convert everything into a closed polyline. This may be automated by an AutoLISP routine, but there should be also a rule to establish the side where the rectangle will "grow". Please do not double your posts; this is just dividing the discussion! Quote
MSasu Posted March 20, 2014 Posted March 20, 2014 Unfortunately without effect; it just appeared again... Quote
Sooshiant Posted March 20, 2014 Author Posted March 20, 2014 Sorry I'm new to here and don't do it again. Thanks for your answer. Quote
