boyo Posted December 3, 2008 Posted December 3, 2008 Is there a way to keep isolines when the solids are exploded. Whenever I explode a 3dsolid via two stage xplode, isolines (the vertical lines) are gone. Quote
ReMark Posted December 3, 2008 Posted December 3, 2008 Why do you find it necessary to explode a solid? And why do you want to retain the isolines? Quote
nocturne00 Posted December 3, 2008 Posted December 3, 2008 Is there a way to keep isolines when the solids are exploded. Whenever I explode a 3dsolid via two stage xplode, isolines (the vertical lines) are gone. What solid are you exploding? a cylindrical object or an object similar to a cube Quote
