I need help to remove some lines in a drawing. I can only see the lines when I use the command "overkill". The lines are grey if that could help.
// Philip
May attempt then to define a filter based on entity type (line), respectively color in QSELECT command.
If this doen't help, please post a copy of said drawing here - just remove everything except few of those troble-maker grey lines.
Thanks mate!
// Philip
