Hello anybody...:unsure:
; error: An error has occurred inside the *error* functionAutoCAD variable
setting rejected: "CMDECHO" nil
Anytime I run a lisp it craps out as soon as the command is executed
Also every time I set the CMDECHO variable back to (1) it resets back to (0) as soon as the Lisp is exected.
I had cleaned out the Lisp command that I believe was the culprit but it is
still having the problem.
Any direction on this will be greatly appreciated.
change this in your error code
from
(setvar "cmdecho" a)
to
(if a (setvar "cmdecho" a))
This was noted by Tharwat on my previous thread.
And Where may I find the error code?
Nevermind... I uloaded all of my lisps, and reloaded the previous working ones. Then I guess I will trouble shoot each one till I load the faulty one,
and make the corrections you have instructed me with.
Thanks...
