Redefining a block via a custom marco button
mrgrotey
 Share
Hi guys, long time no post.
I have a LOT of drawings all with the same block in and I have updated the block so therefore want to redefine all the blocks, ...as you do.
I only have autocad LT 2010 so havent got the LISP coding option.
I am trying to do it by assigning the following example code to a button and running it. The only problem is it doesn't run it properly...
block name for example is 'box'
C^C^_-insert;box=C:\users\michael\desktop\box.dwg;y;C^C^
All the individual lines work when typed but when used in the button macro it stops at:
C^C^_-insert;box=C:
...and doesnt accept the backslash and so stops the macro from continuing.
How can I get it to run a file path??? this is doing my swede in :)
 Share
