Hello all,
I know that circle entity can be converted to wipeout polygon via ALISP routine you can find on http://www.lee-mac.com...
How can we create wipeout with hole inside, or better can we convert hatches to wipeouts?
It seems that this is only solution... Look here...
But my CAD Background is almost black, and white color is plotted as black, but color 255,255,255 which is also white is plotted like mask... I can't differentiate between white or black unless I don't change CAD Background color and white Background tires my eyes while working... So can this 255,255,255 color be set while plotting as white (paper is white) and in CAD environment to be seen as black 0,0,0...
I've solved this problem successfully with this simple piece of code... Hope it will help and others as it helps me... I've put it into my startup suite...
(defun c:bhwipeout ( / adoc True->RGB ss i orlay lay bckmodcol rgb bound )
 (vl-load-com)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (defun True->RGB ( c )
   (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(8 16 24))
 (setq orlay (getvar 'clayer))
 (if (not (tblsearch "LAYER" "HATCH-WIPEOUT"))
   (setq lay (vla-add (vla-get-layers adoc) "HATCH-WIPEOUT"))
   (setq lay (vla-item (vla-get-layers adoc) "HATCH-WIPEOUT"))
 (vla-put-plottable lay :vlax-false)
 (setq bckmodcol (vlax-variant-value (vlax-variant-change-type (vla-get-graphicswinmodelbackgrndcolor (vla-get-display (vla-get-preferences (vlax-get-acad-object)))) vlax-vbstring)))
 (setq rgb (reverse (true->rgb (atoi bckmodcol))))
 (command "_.layer" "_S" "HATCH-WIPEOUT" "_C" "_T" (strcat (itoa (car rgb)) "," (itoa (cadr rgb)) "," (itoa (caddr rgb))) "" "")
 (setvar 'clayer orlay)
 (setvar 'hpname "SOLID")
 (prompt "\nSelect boundary entities for wipeout hatches")
 (setq ss (ssget (append (list '(-4 . "<or") '(0 . "CIRCLE") '(-4 . "<and") '(0 . "*POLYLINE") '(-4 . "<not") '(-4 . "&=") '(70 .  '(-4 . "not>") '(-4 . "&=") '(70 . 1) '(-4 . "and>") '(-4 . "<and") '(0 . "SPLINE") '(-4 . "&=") '(70 . 1) '(-4 . "and>") '(-4 . "<and") '(0 . "ELLIPSE") '(41 . 0.0)) (list (cons 42 (* 2 pi))) (list '(-4 . "and>") '(0 . "REGION") '(-4 . "or>")))))
 (setq i -1)
 (while (setq bound (ssname ss (setq i (1+ i))))
   (if (>= (atof (substr (getvar "acadver") 1 4)) 18.0) (setvar 'hpcolor "255,255,255") (setvar 'cecolor "RGB:255,255,255"))
   (command "_.draworder" bound "" "_F")
   (command "_.-bhatch" "_S" bound "" "")
   (setvar 'clayer "HATCH-WIPEOUT")
   (if (>= (atof (substr (getvar "acadver") 1 4)) 18.0) (setvar 'hpcolor "ByLayer") (setvar 'cecolor "ByLayer"))
Regards, M.R.
Edited by marko_ribar
code changed
  • 3 years later...
