Hi, object snap is open but I cant catch end or mid point of a line?
OSnaps are either "enabled" or "disabled". Did you check your settings to see if both endpoint and midpoint are enabled? If so did you mistakenly hit the F3 key which also turns OSnaps on and off?
it is open and I ticked endpoint and midpoint but nothing changes here is the picobject snap is open.png
Do you want full screen?
Could you be referring to Grips?
I cant understand the question, what is grip? Can you widen it please?
I thought you might be confusing grips with osnaps.
Attach a copy of the drawing to your next post.
Check this: Options> Drafting tab> AutoSnap Settings> Marker. Is it enabled?
I wasn't asking to see an image of your drawing; I was asking for a copy. There's a difference.
If you start a new drawing and enable OSnaps do they work?
Probably I understand what is the problem, If I want to work them I have to activate line command, am I true?
It helps if you are in a command like line, or copy, or move, etc. Since you weren't in a command based on what I saw in your image I thought you were referring to grips which one would see just by clicking on an object even though no command has been invoked.
Can you show me what are grips and are all the status toggles work with an active command as do object snaps (which was my problem)
Click on a line. Do you see any blue squares? If so, they are grips.
Thanks you a lot
Grips can be used to do many things. You might want to check your Help files to find out more about how useful they can be.
