jdbond Posted April 1, 2014 Share Posted April 1, 2014 who has the lips for transfer cordinate to excel. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 1, 2014 Share Posted April 1, 2014 Welcome to CADTutor . Do you mean just only the XYZ for points objects in three columns ? Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 1, 2014 Share Posted April 1, 2014 Please check the EATTEXT built-in command. Quote Link to comment Share on other sites More sharing options...
jdbond Posted April 1, 2014 Author Share Posted April 1, 2014 Yes. when we hit the points or object its can transfer to excelll Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 1, 2014 Share Posted April 1, 2014 You're looking for a lisp routine? I doubt you'll find one that works as you have described but there are some that will transfer data between AutoCAD and Excel. Quote Link to comment Share on other sites More sharing options...
aloy Posted April 1, 2014 Share Posted April 1, 2014 Remark, Could you give one that transfers from Excel to AutoCAD Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 1, 2014 Share Posted April 1, 2014 Yes. when we hit the points or object its can transfer to excelll Try this and let me know . (defun c:Test (/ f ss o i e p) ;; Tharwat 01.Apr.2014 ;; (princ "\n Select points to write coordinates to file :") (if (and (setq ss (ssget '((0 . "POINT")))) (setq f (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv")) ) (progn (setq o (open f "W")) (write-line "X;Y;Z" o) ((lambda (i / n e p) (while (setq n (ssname ss (setq i (1+ i)))) (write-line (strcat (rtos (car (setq p (cdr (assoc 10 (entget n))))) 2) ";" (rtos (cadr p) 2) ";" (rtos (caddr p) 2)) o) ) ) -1 ) (close o) (princ (strcat "\n" f)) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
jdbond Posted April 2, 2014 Author Share Posted April 2, 2014 thanks guy:D Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 2, 2014 Share Posted April 2, 2014 thanks guy:D You're welcome Quote Link to comment Share on other sites More sharing options...
