Hi there, So im currently having this issue which im sure is easy but i dont know how to do it haha.
basically i was using AC2006 prior and when i was working with spreadsheets imported from excel i would put symbols over the chart after and i would be able to select them and move them around within the chart as long as it was sent to the back.
Well now in 2009 if i try to select the objects it selects that object and the chart and it tris to move the whole thing.
i know this is probably confusing and any hellp would be appreciated
Ive never had this problem, but have you tried locking the layer the chart is on? There might be other solutions but that might work
