mostafa badran Posted April 5, 2014 Share Posted April 5, 2014 hi all,I need help, I need lisp which can remove $ from layer name ,block name ,style text ,etc. with explain the steps of syntax of lisp. thanks for help. mostafa Quote Link to comment Share on other sites More sharing options...
tzframpton Posted April 5, 2014 Share Posted April 5, 2014 You can already accomplish this with the RENAME tool, utilizing wildcard matches to edit all names in these categories. Quote Link to comment Share on other sites More sharing options...
mostafa badran Posted April 5, 2014 Author Share Posted April 5, 2014 You can already accomplish this with the RENAME tool, utilizing wildcard matches to edit all names in these categories. Thanks tzframpton fro respond,can you to clarify more,there's too much layers, blocks,the RENAME tool renamed as single category. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted April 6, 2014 Share Posted April 6, 2014 Start withthis one (defun c:BF ;///////////////////////////////////////////////////////////////////////// ; ; BindFix15.lsp (AutoCAD 2000+) ; ; Copyright 2003 | Michael Puckett | All Rights Reserved ; ;///////////////////////////////////////////////////////////////////////// ( / ; local defuns __GetTableEntries __RenameTableEntry __RenameTableEntryViaObjname __RenameTableEntryViaActiveX __StripBindingArtifacts __GetUniqueTableEntryName ; local vars doc newname ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __GetTableEntries ( table / data result ) (while (setq data (tblnext table (null data))) (setq result (cons (cdr (assoc 2 data)) result) ) ) result ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntry ( doc table oldname newname / data ) ; wrapper for __RenameTableEntryViaObjname ; and __RenameTableEntryViaActiveX functions (setq table (cond ((eq (setq table (strcase table t)) "ltype") "linetype") (t table) ) ) (if (member table '("style" "dimstyle")) ; autodesk made textstyles and dimstyles read-only to ; the automation model w/regards to the symbol name, why? (__RenameTableEntryViaObjname table oldname newname) (__RenameTableEntryViaActiveX doc table oldname newname) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntryViaObjname ( table oldname newname / data ) ; calling function responsible for ; ensuring appropriate data passed (entmod (subst (cons 2 newname) (assoc 2 (setq data (entget (tblobjname table oldname)))) data ) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntryViaActiveX ( doc table oldname newname / data ) ; calling function responsible for ; ensuring appropriate data passed (vla-put-name (vla-item (eval (list (read (strcat "vla-get-" table "s")) doc ) ) oldname ) newname ) ; if you wanted this to be more robust ; you could use the following ... ; ; (vl-catch-all-apply ; (function ; (lambda () ; (vla-put-name ...) ; ) ; ) ; ) ; ; I chose to pass valid data instead ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __StripBindingArtifacts ( entry / i done ) (cond ( (wcmatch entry "*`$#`$*") (setq i 0 ceiling (strlen entry)) (while (and (not done) (< i ceiling)) (if (wcmatch (substr entry (setq i (1+ i)) 3) "`$#`$*") (setq entry (substr entry (+ i 3)) done t ) ) ) ) ) entry ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __GetUniqueTableEntryName ( table entry ) (cond ( (tblsearch table entry) (setq i 1) (while (tblsearch table (strcat entry "_" (itoa (setq i (1+ i)))) ) ) (strcat entry "_" (itoa i)) ) ( t entry ) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; "main" ; ;///////////////////////////////////////////////////////////////////////// (cond ( (< 14 (atoi (getvar "acadver"))) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (foreach table '("block" "dimstyle" "layer" "ltype" "style") (foreach entry (reverse (__GetTableEntries table)) (cond ( (wcmatch entry "*`$#`$*") (__RenameTableEntry doc table entry (setq newname (__GetUniqueTableEntryName table (__StripBindingArtifacts entry) ) ) ) (princ (strcat "\n" (if (tblsearch table newname) (strcat "Renamed " table " " entry " => " newname "." ) (strcat "Could not rename " table " " entry "." ) ) ) ) ) ) ) ) ) ( t (princ "\nSorry, penned for AutoCAD 2000+.")) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
mostafa badran Posted April 6, 2014 Author Share Posted April 6, 2014 Start withthis one (defun c:BF ;///////////////////////////////////////////////////////////////////////// ; ; BindFix15.lsp (AutoCAD 2000+) ; ; Copyright 2003 | Michael Puckett | All Rights Reserved ; ;///////////////////////////////////////////////////////////////////////// ( / ; local defuns __GetTableEntries __RenameTableEntry __RenameTableEntryViaObjname __RenameTableEntryViaActiveX __StripBindingArtifacts __GetUniqueTableEntryName ; local vars doc newname ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __GetTableEntries ( table / data result ) (while (setq data (tblnext table (null data))) (setq result (cons (cdr (assoc 2 data)) result) ) ) result ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntry ( doc table oldname newname / data ) ; wrapper for __RenameTableEntryViaObjname ; and __RenameTableEntryViaActiveX functions (setq table (cond ((eq (setq table (strcase table t)) "ltype") "linetype") (t table) ) ) (if (member table '("style" "dimstyle")) ; autodesk made textstyles and dimstyles read-only to ; the automation model w/regards to the symbol name, why? (__RenameTableEntryViaObjname table oldname newname) (__RenameTableEntryViaActiveX doc table oldname newname) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntryViaObjname ( table oldname newname / data ) ; calling function responsible for ; ensuring appropriate data passed (entmod (subst (cons 2 newname) (assoc 2 (setq data (entget (tblobjname table oldname)))) data ) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __RenameTableEntryViaActiveX ( doc table oldname newname / data ) ; calling function responsible for ; ensuring appropriate data passed (vla-put-name (vla-item (eval (list (read (strcat "vla-get-" table "s")) doc ) ) oldname ) newname ) ; if you wanted this to be more robust ; you could use the following ... ; ; (vl-catch-all-apply ; (function ; (lambda () ; (vla-put-name ...) ; ) ; ) ; ) ; ; I chose to pass valid data instead ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __StripBindingArtifacts ( entry / i done ) (cond ( (wcmatch entry "*`$#`$*") (setq i 0 ceiling (strlen entry)) (while (and (not done) (< i ceiling)) (if (wcmatch (substr entry (setq i (1+ i)) 3) "`$#`$*") (setq entry (substr entry (+ i 3)) done t ) ) ) ) ) entry ) ;///////////////////////////////////////////////////////////////////////// ; ; local defun ; ;///////////////////////////////////////////////////////////////////////// (defun __GetUniqueTableEntryName ( table entry ) (cond ( (tblsearch table entry) (setq i 1) (while (tblsearch table (strcat entry "_" (itoa (setq i (1+ i)))) ) ) (strcat entry "_" (itoa i)) ) ( t entry ) ) ) ;///////////////////////////////////////////////////////////////////////// ; ; "main" ; ;///////////////////////////////////////////////////////////////////////// (cond ( (< 14 (atoi (getvar "acadver"))) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (foreach table '("block" "dimstyle" "layer" "ltype" "style") (foreach entry (reverse (__GetTableEntries table)) (cond ( (wcmatch entry "*`$#`$*") (__RenameTableEntry doc table entry (setq newname (__GetUniqueTableEntryName table (__StripBindingArtifacts entry) ) ) ) (princ (strcat "\n" (if (tblsearch table newname) (strcat "Renamed " table " " entry " => " newname "." ) (strcat "Could not rename " table " " entry "." ) ) ) ) ) ) ) ) ) ( t (princ "\nSorry, penned for AutoCAD 2000+.")) ) (princ) ) Thanks Mr asos2000 I will try this,thanks for your response. Quote Link to comment Share on other sites More sharing options...
