jrharv Posted April 7, 2014 Posted April 7, 2014 Layer properties were copied to a printable layer, all layers on/thawed in model and paper space. Audit fixed nothing, claims no errors. Regenall still fails to show text in paper space. Restart of Autocad did nothing. Restart of PC did nothing. acad 2012 version. Quote
Dana W Posted April 7, 2014 Posted April 7, 2014 We will need to know more about the drawing. Is the text in paperspace or modelspace? Is the text annotative? Can you see the text in the paperspace layout? Does the text show in the plot preview? Can you post the dwg file where this behavior shows? Quote
ROBP Posted April 7, 2014 Posted April 7, 2014 running white background with with black text is gess check your pst because white cannot print on white unless you use monochrome and pst text layer is set to print black or text was on viewport layer and layer was preset not to print just a clue Quote
Dana W Posted April 7, 2014 Posted April 7, 2014 or text was on viewport layer and layer was preset not to print just a clue That might be it. Everyone forgets when they learned to no plot the viewport layer, or have it in the template, and occasionally we all forget to change the paperspace layer after setting up the viewport. On my laptop, I can't see the right side of the layer manager without scrolling to the right, so when I go check the switches I say "Nope, all on and thawed, good to go." That's why I make the viewport a color that I never use anywhere else. Then my dimensions or notes tell me right away what I have done wrong. Why are these orange? Oh, yeah. Quote
RobDraw Posted April 8, 2014 Posted April 8, 2014 My guess. It's annotative text and the settings need to be done correctly. Quote
jrharv Posted April 8, 2014 Author Posted April 8, 2014 Sorry for delay. It was annotative, as it was begun by another draftsman, I expected it to be on Standard text style. Annotative is a serious pain. Quote
RobDraw Posted April 8, 2014 Posted April 8, 2014 You have two options. Remove the annotative property or set the scales properly. Quote
jrharv Posted April 8, 2014 Author Posted April 8, 2014 I retyped all the text in a style that was not annotative. Typing has never been an Autocad strong suit. This mess doesn't happen when I have complete control of the drawing. Quote
RobDraw Posted April 8, 2014 Posted April 8, 2014 Ooops, third option that I would not even consider. You should have posted before typing. Could have saved you some work. Quote
