Updating field-to-field-to-field
I'm using fields quite a lot in my drawings, all good. I also use fields to refer to other fields, wich refer to other fields etc. So when i need them to update, only the first in line field will be updated. So for every step i need to run a fieldupdate action. Does anybody experience this same thing and/or does anybody have a tip to, for example "deep"-update all those fields?
thanx in advance!
  • 3 weeks later...
hi,
to close my monologue :P I assigned a macro to a button. Its not exactly what i wnated, but it does the trick:
^C^C_updatefield all updatefield all updatefield all updatefield all updatefield all regen
cheers
I'm not sure if this will help, but what is your setting for 'fieldeval' it is as standard 31, which should update all fields when you do a regen (except dates apparently)
