Frozee Posted April 8, 2014 Posted April 8, 2014 My first post, hopefully someone can help. Using AutoCAD LT 2015, I am trying to figure out a way to calculate the linear inches of each line from a simple drawing including text. I am not sure if AutoCAD has the capability. I have attached an example. 03-0423_ENGRAVING_BOP_PANEL dwg.dwg Quote
MSasu Posted April 9, 2014 Posted April 9, 2014 To measure the length of the lines please look for DIST, MEASUREGEOM or LIST. You may also extract the lengths to a file using DATAEXTRACTION command,although not sure how will differentiate them. Quote
