How do I insert a raster image that is drawn at 1/8" to a drawing at full scale 1:1.
hello...
this site is new to me but to answer your questio::: i usually save my image as a block? (Using WBLOCK command) and then insert the image from block editor (Insert>Block editor) ---this would bring up the block editor tool pallette--- from parameters I choose the part of the image I want to scale and then from actions choose scale to your preferred size!
this is when the scale command does'nt help i guess!
If the image has a dimension them measure that and work out the scale factor then just use "Scale", I would be skeptical that the image is exactly 1/8" scale. look for something that you know the size of.
A little trick to use with Al's suggestion: The reference option in the scale command is a great way of doing this.
