I have a file: section.dwg, which has an xref-ed file: floorplans.dwg.
Now, I'm trying to create a separate file, elevations.dwg, and xref the other two files separately.
When I xref the sections.dwg acad brings in the floorplans.dwg (the attached one). I would like to have the ability to move around the sections.dwg (without the xrefed floorplans) and floorplans.dwg independently in the elevations.dwg.
The question is:
Can I unload the floorplans.dwg fom sections.dwg (only in the elevations.dwg) and bring it as a separate xref?
Omg, I hope this was not confusing to much :o
Thank you for your time and help :)
Explore the WBLOCK command, you'll like it. :)
aaaaaaaaaaa :))) :facepalm:
Thx for the idea :)
In Sections.DWG change the xref-type on Floorplans.dwg to Overlay - that way it doesn't come with Sections.dwg when you xref it.
Then you can x-ref both Sections.dwg and Floorplans.dwg into your elevations-dwg and have the there individually.
Thank you :notworthy:
That was genius
Aw schucks, You are too kind. :oops:
(but please keep the compliments coming :thumbsup: )
