Openantics Posted April 12, 2014 Posted April 12, 2014 when building a surface and displaying elevation ranges, i like to use the integrated C3D color scheme 'Rainbow', however I need the colors reversed! currently the Rainbow color asscoiation is: red = low elevation, blue high elevation. Is it possible to edit this dynamic color scheme and reverse it, or build my own? tia, oa FYI - I am plotting bathymetric data, so deeper water (lower elevation) should be displayed as blue, and shallow water (higher elevation) depicted in red Quote
JerryG Posted April 14, 2014 Posted April 14, 2014 I think what you want to look at is "Watersheds" Make Watershed visable then go over to the Watershed Tab (all under Surface Style) The Watershed tab allows you to change the color / hatch of depressed areas etc. Quote
Openantics Posted April 26, 2014 Author Posted April 26, 2014 sorry to reply so late. i have not had a chance to try your suggestion. thanks for the reply oa Quote
