Need a Lisp to Zoom fit model space rectangle on layout View.
Hi Saqib_thelo,
the BoundingBox is always calculated in WCS...
To use the same method in UCS I have recurred to two Gilles Chanteau's excellent functions, the gc:TMatrixFromTo and gc:UcsBoundingBox.
(defun c:demo ( / a b e)
 (vl-load-com)
;; by Gilles Chanteau
;; gc:TMatrixFromTo
;; Retourne la matrice de transformation (4x4) d'un système de coordonnées
;; vers un autre (mêmes types d'arguments que trans)
;; Arguments
;; from : système de coordonnées de départ (entier, vecteur ou ename)
;; to : système de coordonnées de destination (entier, vecteur ou ename)
(defun gc:TMatrixFromTo	(from to)
 (append
   (mapcar
     (function
(lambda	(v o)
  (append (trans v from to T) (list o))
     (list '(1. 0. 0.) '(0. 1. 0.) '(0. 0. 1.))
     (trans '(0 0 0) to from)
   (list '(0. 0. 0. 1.))
;; gc:UcsBoundingBox
;; Retourne les coordonnées SCU de l'emprise (bounding box) de l'entité
;; par rapport au SCU courant.
;; Arguments
;; obj: une entité (ENAME ou VLA-OBJCET)
;; _OutputMinPtSym: un symbole quoté (output)
;; _OutputMaxPtSym: un symbole quoté (output)
(defun gc:UcsBoundingBox (obj _OutputMinPtSym _OutputMaxPtSym)
 (vl-load-com)
 (and (= (type obj) 'ENAME)
      (setq obj (vlax-ename->vla-object obj))
 (vla-TransformBy obj (vlax-tmatrix (gc:TMatrixFromTo 1 0)))
 (vla-GetBoundingBox obj _OutputMinPtSym _OutputMaxPtSym)
 (vla-TransformBy obj (vlax-tmatrix (gc:TMatrixFromTo 0 1)))
 (set _OutputMinPtSym
      (vlax-safearray->list (eval _OutputMinPtSym))
 (set _OutputMaxPtSym
      (vlax-safearray->list (eval _OutputMaxPtSym))
 (if (setq e (car (entsel "\nSelect Rectang : ")))
     (gc:UcsBoundingBox e 'a 'b)
     (vl-cmdf "_.zoom" a b)
Without using the BoundingBox method, maybe something like this will be enough
(defun c:demo (/ a b o ss)
 (vl-load-com)
 (if (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE")(-4 . "&=")(70 . 1))))
     (setq o (vlax-ename->vla-object (ssname ss 0))
    a (vlax-curve-getpointatparam o 1)
    b (vlax-curve-getpointatparam o 3)
           (vl-cmdf "_.zoom" (trans a 0 1) (trans b 0 1))
Hope that helps
Henrique
  • Replies 31
  • hmsilva
    9
  • Saqib_theleo
    7
  • EBROWN
    6
  • janaudie
    3
Hi Henrique,
Many thankss. Both codes are working nice on changed UCS.
Thanks for you time and help. GBY.
You're welcome, Saqib_thelo
Glad I could help
Henrique
Thank you Henrique.
Using the first program I can select a polyline or block. Using the second program I can not select the block only a polyline.
I have tried to add the step to lock the viewport but failed. Could you add that step to the programS.
Thanks
EBROWN
Henrique,
I gave it one more try and I was able to add the step to lock the viewport.
Thanks
EBROWN
Hi EBROWN,
glad you got a solution
Henrique
  • 5 years later...
It says this error
Select Rectang : ; error: no function definition: VLAX-ENAME->VLA-OBJECT
How to fix this?
6 hours ago, janaudie said:
It says this error
How to fix this?
Add (VL-LOAD-COM) to the code.
I added the (vl-load-com) but still the same error.
On 10/03/2020 at 22:28, janaudie said:
It says this error
How to fix this?
Any update for this error? it's the same error when (vl-load-com) will be added. sorry I'm not expert on lisps
  • 2 years later...
On 4/18/2014 at 7:56 PM, hmsilva said:
Hi EBROWN,
(defun c:demo (/ a b e o)
 (vl-load-com)
 (if (and (= (getvar 'TILEMODE) 0)
   (/= (getvar 'CVPORT) 1)
     (setq o (vlax-ename->vla-object e))
     (vlax-invoke-method o 'GetBoundingBox 'a 'b)
     (setq a (vlax-safearray->list a)
    b (vlax-safearray->list b)
     (vlax-put	(vla-get-activepviewport
	  (vla-get-activedocument (vlax-get-acad-object))
	'DisplayLocked
	:vlax-true
HTH
Henrique
I want to add when you select the viewport if it is Locked remove it !
(defun SSVPLock ( ss lock / i )
      (if ss (repeat (setq i (sslength ss))
                (vla-put-displaylocked (vlax-ename->vla-object (ssname ss (setq i (1- i)))) lock) t ) ))
;;Unlocks Selected Viewports / Requires a pick
(if (SSVPLock (ssget "_+.:E:S:L" '((0 . "VIEWPORT"))) :vlax-false)
(princ "\n--> Viewport Unlocked."))
